Originally Posted by morsejon
I just bought a 2007 TCH. I would like to improve the curb appeal of the car without compromising the performance (both ride and MPG) so I am looking to either upgrade to after market rims (prob 18s) or lower the car with the TRD springs (well SE & TRD springs as recommended in other posts).
Any thoughts?
How good a job does your DOT do on roads and pothole fixes? Larger, heavier wheels, in combination with low-profile tires are much more likely to have pothole bends and blowouts, as well as a rattle-inducing ride. Also, unless you mount Low Rolling Resistance tires, you will get a significant MPG hit. You can compensate a bit for this by increasing tire pressures, but at a cost of ride quality.
If the road quality is good in your area and you're OK with the rougher ride and typically shorter tire life, go for it. If your commute is pothole-filled the oversize (especially with heavier wheel/tire combo) will create problems.
