i have 07 TCH with 56 000 miles.
saturday i have noticed that coolant level in expansion canister was at the bottom mark.
i filled canister up to top mark. did not drive her much over the weekend, but slid 2 cardboards underneath.
checked on them today.
of course, them new coolants, one can't even tell if it's coolant or not.
there are several stains with some clear fluid on cardboard, right next to driver side wheel.
they are right below hybrid drive.
for what it is, i could not tell if it's water or coolant. what happened to good old green or blue stuff?
i could not find any obvious leaks, etc. there's minor streak down along driver side hub. but it's been raining here, so there's no telling..
what can possibly leak on that side? HSD has it's own coolant, but it's red, would have been obvious. also, its level was OK in its expansion canister.
radiator hoses, esp bottom ones, run all the way over there, but i could not spot any leaks, or sediments. she does not smell of burnt coolant driving.
any ideas? of course, all this has to be right underneath that high voltage box for HSD.
my wife's LexusRX300 dropped coolant level in expansion canister down to mid between the marks 2 weeks ago. maybe because it was cold outside. i topped it to the upper mark, and it stays there. not sure if the same caused level drop in TCH. i'll monitor, but start freaking out.
