REMOVING/REPLACING Driver's Side Mirror on 08 Camry Hybrid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2011, 11:53 AM   #1 (permalink)
View pinchepunx's Photo Gallery
My mirror was knocked off by another driver this morning and is hanging by the wires. I want to remove it so it doesn't scratch the paint. Does anyone have instructions on how to do this?
I think its simple but haven't found anything reliable online yet. Thanks!!!
pinchepunx is offline   Reply With Quote
Old 01-14-2011, 01:10 PM   #2 (permalink)
Buyer's remorse
View razol's Photo Gallery
It is pretty easy to fix this:
1. Pry off the triangle plastic cover.
2. Inside are three bolts with with a nut on each. Just use a socket wrench to remove the three nuts.
3. Unclip the plastic wire clip
I should warn you though that this is going to leave a hole to the outside which you will need to temporarily seal with plastic/tape and then re-attache the plastic cover until you get a new mirror. You will have some significant wind noise until you replace it.
razol is offline   Reply With Quote
The Following User Says Thank You to razol For This Useful Post:
crkohl (01-17-2011)
Old 01-14-2011, 01:21 PM   #3 (permalink)
Thanks!!!
