If your car is equipped with Navigation, there are actually two areas that must be reset.
The first is the one that triggers the "Maintenance Req'd" text and triangle within the info center in the instrument cluster. This is the one that is defaulted to 5,000 miles once reset. The dealer usually covers this for you. If the light is off when you pick up the car, then this has already been done and you can be confident that it will nag you again in 4500 miles, then stay on after 5,000.
The second is within the Maintenance sections on the INFO part of the navigation menu. This one has a setting for the Engine Oil and Oil Filter separately. Do not ask me why it is not just "Oil Change" since they are always together. This one is always neglected by the dealer and you need to remember to set it yourself when you pick up the car (if you care about being warned on the nav screen).
Personally, I find both of them to be unnecessary as this car is easy to remember to change every 5,000.
