Originally Posted by Daniel Bunny
I own a 2007 toyota camry hybrid. I am looking to install aftermarket rims, so I need you opinion on two of my choices.
Drag DR 42s (1st) or Drag DR 37s (Second)
The car they would go on is in my sig.
Do realize that oversize wheels, especially when combined with tires that are not Low Rolling Resistance will decrease your mileage and make the performance a bit slower. The most critical dimension is the total weight of the wheel/tire combination; the heavier it is, the worse your penalty. The weight increase will also do damage to ride that's over and above the harshness from the shorter, stiffer tire sidewall.
If you do go with lightweight forged wheels and the right tire to stay (or even go below) the stock wheel weight, you will minimize the ride and handling impacts.
