Originally Posted by msbwo
My 2008 TCH had problems when I bought it. The check hybrid system light would come on. I checked the 12v battery and was discharging at a fast rate. After going to 2 dealers, the inverter/converter was changed and the 12v battery stays charged. According to the manual and Toyota Headquarters, the 12 volt battery should stay charged like a regular car. I let my set 4 days a week. I will then drive it 15 miles and the 12volt battery will be at 12.6 volts after the car sets 2 hours.
So the "inverter" was the problem. Why did you have to go to two dealers to have it fixed?
Were they arguing with you that everything was OK?
The "inverter", is it that expensive part about $8K ?
