Battery questions - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2012, 04:26 PM   #31 (permalink)
View soflada's Photo Gallery
Jim,
The info ukrkoz posted about how to use Optima Batteries comes from this website:
http://www.elearnaid.com/opd35fortoca.html
soflada is offline   Reply With Quote
The Following User Says Thank You to soflada For This Useful Post:
OptimaJim (01-06-2012)
Old 01-05-2012, 03:50 PM   #32 (permalink)
View OptimaJim's Photo Gallery
soflada, thanks for posting that link and reviving this thread. Since this thread began, we did release a Prius-specific replacement battery, the DS46B24R YellowTop, which can be safely mounted in enclosed spaces, due to it's provisions for external venting. The information on the link you provided does specifically indicate in bold print, “if the valves do release they vent directly and there is no place to attach the vent tube.” in reference to our Group D35 YellowTop.
Jim McIlvaine
eCare Manager, OPTIMA Batteries, Inc.
www.facebook.com/optimabatteries
OptimaJim is offline   Reply With Quote
Old 01-05-2012, 03:54 PM   #33 (permalink)
In the case of the TCH, what measurements do you suggest for either the OEM battery (seems to be a Panasonic) or your Optima to measure what kind of life is left in them? Is the measurement similar to other deep cycle batteries such as those found on sailboats?
TIA
David
Old 01-05-2012, 11:27 PM   #34 (permalink)
View geezer43's Photo Gallery
I had my battery replaced at independent repair shop and they did not install the vent tube. I cannot figure out how to install the tube in battery fitting. My dealer will not help me and the independent shop too far away. Can you help me?
Sent from my DROIDX using AutoGuide.Com Free
geezer43 is offline   Reply With Quote
Old 01-06-2012, 10:08 PM   #35 (permalink)
David, even though the fitment guide on our website indicates our Group 35 RedTops and YellowTops are suitable repalcements for Toyota Camry Hybrids, neither of those batteries has provisions for external venting and I cannot recommend a “direct-fit” replacement. I can tell you that the previously-mentioned DS46B24R battery does have external venting provisions, as well as our Group 78 RedTop and Group 27, 51, 34C & Group 31 batteries.
You can view the dimensions and all the performance specifications for all of our YellowTops here and all of our RedTops here as they will vary, based on size and color.
Geezer, without knowing what kind of battery was installed in your car, it would be difficult for anyone to offer you assistance, as the battery installed may not have external venting provisions. Typically, batteries that do have such provisions simply have small ports, where a vent hose (or hoses) can be attached to the battery. If you can post a few pictures of your battery it may be apparent whether the battery was equipped with vent ports and where they might be.
Jim McIlvaine
Old 01-07-2012, 10:33 PM   #36 (permalink)
ukrkoz's Avatar
Gameroom cash: $189750
View ukrkoz's Photo Gallery
guys, you do not need red tops. they are starting batteries. you need yellow tops, they are "storage" batteries, made for slow discharge and large capacity backup for electronics. you should not be concerned with cranking (red) power, but with capacity(yellow) feature.
Jim, told you before and will repeat myself, though I know your answer from previous posts. your batteries do have openings with porous plugs, for outside venting. concern is, they vent directly into the trunk. though it's highly unlikely, as it's AGM batteries, there will be any hydrogene leak, AND COLLECTION OF IT TO DANGEROUS POINT, IN NON-SEALED TRUNK, of hydrogen, I do understand reluctance in recommending them.
like I said before - there is a very easy way to add proper tubes to yellow top, WITHOUT ANY MODIFICATIONS TO BATTERY, to connect them to OEM hydrogen vent tube. it's an outside add on, saying it's voiding warranty is like saying that battery bracket voids it too, because it is attached to the battery outside.
ukrkoz is offline   Reply With Quote
