18" Wheel Questions - Anyone w/experience please read - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2011, 10:55 PM   #1 (permalink)
View MXZDrew's Photo Gallery
New to the forum, new to our 07' TCH. Loving both! Looks like a good group on here as well!
I just picked up a set of 11' Scion TC Wheels w/ 215/45/18 Yoko's mounted on them. I have a couple of questions on the subject. I have searched hard and thats why I went ahead with the purchase. I just wanted to verify and poll some users out there.
My main concerns are the following:
#1 - Those of you who did switch to 18's with this tire size, how bad of a MPG hit did you notice? I know there will be some as the wheel/tire combo are about 5lbs heavier each.
#2 - The TC wheels are 7.5" with a +39 offset vs. the factory 6.5" with a +45 offset. My calculations I ran say the wheel will stick out 19mm more. From what I have read, the car can handle an offset with a range of +35-45.
Can anyone confirm I will be ok with this offset? No harm to the driveline? I don't think they would rub even if I lowered which I do not plan on doing. Would you agree?
Sometimes when things are this close and all my searching provides no conclusive results then it's better to just try. I will be reporting hard facts as well as pics of the TC wheels on a Magnetic Grey 07' TCH which I expect will look pretty good!
MXZDrew is offline   Reply With Quote
Old 04-06-2011, 06:39 PM   #2 (permalink)
the Maxima guy...
Chunger's Avatar
View Chunger's Photo Gallery
Given the same overall tire diameter and width (size). The TC rims would stick "out" an additional 6mm (45-39mm) assuming your numbers are correct.
My OZ 18" with old 245/40 ContiExtremes weighed less than the TCH rim/tire combo by about 1/2 lb each. MPG drop was like 1 mpg less due to rolling resistance probably... highly unscientific MPG figures, though, as it is hard to "have all things equal" (i.e. not a factor).
2007 loaded TCH with 4300K HIDs and 235/45/18s
2012 HiHy Limited
Chunger is offline   Reply With Quote
Old 05-20-2011, 01:04 PM   #3 (permalink)
pop11's Avatar
View pop11's Photo Gallery
MPG will go down a little bit in city but wont effect much on highway.
2008 Camry Hybrid ::
19" X 8" +33 W Work Euroline 225/40 W Work Extended lug Nuts
KYB Struts / H&R Springs
pop11 is offline   Reply With Quote
Old 05-20-2011, 04:29 PM   #4 (permalink)
ukrkoz's Avatar
Gameroom cash: $189750
View ukrkoz's Photo Gallery
all you had to do is to read your manual. 18" inchers are said to drop mpg down by 1 mile to gallon. we had a discussion on this here not so long ago, and it was "no big deal" theme.
well, do your math. at $4 a gallon, divided by 37mpg average, it is 10.8 cent a mile. at 36mpg it is 11.1 cent. or, .3 cent difference a mile. personally, I drive around 2000 miles a month. that is 6 bucks difference a month, or $72 a year.
ukrkoz is offline   Reply With Quote
Old 05-21-2011, 11:57 AM   #5 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Putting the TC rims on will be just fine. There are members on here with Camrys that put 20" rims on with no problems. And with any heavier wheel/tire combo, your gas mileage will suffer a little bit, but not by too much.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 05-22-2011, 10:09 AM   #6 (permalink)
Gameroom cash: $197815
View Frodo65's Photo Gallery
There's an additional dimension, that of tire life and replacement cost. The larger tire typically carries a considerable cost increase over the OEM tire, and the high-performance variants have significantly shorter wear life. Assuming 45K life for OEM tires, and $200 ea. replacement cost (Michelin OEM V-rated, $159 + $41 for shipping/install, UTOQ 460) vs $335 (Michelin HX MXM4, also V rated, $283+ 50 for shipping/install, UTOQ 300) and a 30K life.
Now, there are other choices that can drive the cost/life compromise in different directions - TR has a Michelin tire at $249 and a UTOQ of 500. But, for a comparable price/performance point, the larger wheel will cost more and won't last as long.
Frodo65 is offline   Reply With Quote
