in follow up to this post:
Putting an amp in a hybrid
the main source of subwoofer caused rattle in my TCH is rear shelf.
I had it somewhat taken care of with a heavy weight on it, but it looked ugly and weight shifted around.
today i figured nice and easy way to silence that shelf.
1. lower the passenger side backrest
2. you will have lowermost plastic shelf cover edge exposed.
3. grab that edge and pry shelf cover up
4. it easily pops off clips, exposing large hollow chamber between the shelf cover and the metal shelf itself.
gives you a moment to appreciate cheap plastic, poorly holding clips, and wonder, what is the purpose of that hollow chamber right next to the large speakers.
anyhow.. Toyota didn't even try to introduce any dampening material there.
5. i, basically, stuffed that chamber with soft stuff. foam, sponges, towels, wall insulation - anything of that nature will work, as far as it compresses to stabilize plastic, but enough for it to be secure back on clips.
that's it! crank your sub up now and enjoy.
next is to chase down cause of occasional rattle somewhere around passenger seat.
oh, and one down in the center console.
