Add Fog Lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2011, 11:40 AM   #1 (permalink)
View DarbDee's Photo Gallery
Add Fog Lights
I have a 2008 TCH and I am adding Fogg Lights.
Questions to ASK and I hope YOU can Answer
#1 The Battery is in the Trunk where should I hook the Relay for the Lights to under the Hood?
#2 Do I need a Relay with 55 Bulbs?
#3 What size wires do I need for this Hook up?
#4 The Fogg Lights came with #18 wire, what size Fuses do i need?
Thanks
DarbDee
DarbDee is offline   Reply With Quote
Old 05-08-2011, 03:00 AM   #2 (permalink)
View jordan_lin's Photo Gallery
Canada
Hi DarbDee
#1 The Battery is in the Trunk where should I hook the Relay for the Lights to under the Hood? yes you should. inside the engine bay fuse box there is constant power you can draw power from or ignition signal.
#2 Do I need a Relay with 55 Bulbs? yes, foglight switch can't handle that much current. so use the switch only to trigger the relay.
#3 What size wires do I need for this Hook up? you said that it comes with #18 wire. that would do. but if you are putting in HID, then you might want to consider 16 gauge.
#4 The Fogg Lights came with #18 wire, what size Fuses do i need? 20amp is plenty.
jordan_lin is offline   Reply With Quote
