If you want aftermarket wheels you can generally swap over your sensors, otherwise the tire light on the dash will stay illuminated. For a TPMS reset button, check under the dash and in the glove box.
If you look at your valve stem, you will see that it's a silver metal, and hard, as opposed to a black rubber stem that's flexible. All newer cars have this system, although some use "band" sensors, so they still have the black rubber stem.
6 speed manual 2011 Camry SE 2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
