Valve Cover Gasket Replacement Cost - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2011, 08:57 AM   #1 (permalink)
View greenwapiti's Photo Gallery
I have 2009 Camry Hybrid with ~70,000 miles on it (yep, I drive it a lot). The service rep just quoted me $301.00 for replacement of the valve cover gasket, which sounds like a high charge for this, and indicated that it isn't covered by warranty or indicated as a problem with this model in any technical service bulletin.
Anyone else have this problem? If so, is the cost I've been quoted out of line with other dealer service for this replacement?
Thanks,
Green
greenwapiti is offline   Reply With Quote
Old 07-13-2011, 10:32 PM   #2 (permalink)
ukrkoz's Avatar
Gameroom cash: $189750
View ukrkoz's Photo Gallery
what problem? stupid as it sounds, why do you have to have it replaced?
ukrkoz is offline   Reply With Quote
Old 07-13-2011, 10:37 PM   #3 (permalink)
ukrkoz's Avatar
out of curiosity, popped plastic cover off mine and took a good look at valve cover. looks like 30 minute job to me. does not appear to have any hidden pockets, connections, pipes running anywhere. donno how much all the seals and gasket will be though, as you'll have to replace spark plug wells seals along with gasket.
Old 07-18-2011, 05:07 PM   #4 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Thanks,
Green
$300 isn't bad. The gasket and other misc. little parts will run you between $30-$50, the rest labor. Generally, most dealerships charge around $100 an hour for labor, keep in mind when they take the gasket off they need to check to make sure the gasket surface is level and doesn't need to be machined. I think it's reasonable.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
