yeah, that's a good one. Sounds like Alaska... Or Canada.
anyhow. depends how much effort you want to put into it, and $$. Block heater is a nice idea, if it does not quit on you or you do not have power outage. depends on how many stars your luck has.
otherwise, coming from a very cold country, when we had winters hitting 40 below Celsius, with cars parked in the streets or, for chosen ones, inside metal garages we, always drained coolant, from radiator and engine block.
we always removed batteries ans stowed them somewhere. you may decide to go with float charger for your 12V battery, as that's the one that does life support for your car ECM.
You may also consider doing something about your garage. You know, a garage warmer may come very handy. We have one hanging off the ceiling in our warehouse. Keeps it at 45 degrees. But then again, it's like block heater. Relying on outside power supply.
Buddy that will come over and check on things is prolly more valuable than all tricks you can come up with.
