or any ethanol containing fuel, for that matter.
Came across interesting technical info today.
Apparently, many modern cars cut short on mechanical sensors, and use "virtual sensors" instead.
E.G., sensors that used to detect amount of ethanol in fuel are obsolete now, and replaced with virtual sensor. That "sensor", in its turn, is an algorithm based on O2 sensor readings.
Here's the cute part:
WHEN O2 SENSORS READS LEAN MIXTURE, ECM INTERPRETS THIS AS ETHANOL PRESENCE IN GASOLINE, AND
REMAPS FUEL SYSTEM AND ENGINE TO HIGHER GASOLINE SUPPLY.
And here goes you mpg....
Source - Popular Mechanics
