take, life happens. stuff falls off the cars on freeways all the time. rocks are being picked by tires and tossed around at high speeds also. all it takes is one of freakish "wrong spot at the wrong time" smacks. I had my CR-V windshield cracked in a half by a tiniest chip, and could not even see where it happened, until dealership adjuster pointed at it to me. things like this might be very hard to notice, should you have entire glass in cracks.
Then again, Honda had TSB issued on Elements. There was imperfection in frame that was causing high stress point in the windshield, resulting in particular cracks starting at the bottom. If you found several end users that had same issue - shattered glass for not apparent reason - write letter to Toyota. Start with customer satisfaction manager, then take it up a notch.
