Water pump leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2011, 07:33 PM   #1 (permalink)
Gameroom cash: $120300
View johnjan's Photo Gallery
Water pump leak
My dealer just told me that my 2008 TCH water pump is showing some a little leak and that it will cost $535 to fix it (parts and labor).
Is there a DIY for the water pump?
johnjan is offline   Reply With Quote
Old 09-07-2011, 08:05 PM   #2 (permalink)
ukrkoz's Avatar
Gameroom cash: $189750
View ukrkoz's Photo Gallery
it's covered under 60 000 warranty. HOW MANY MILES? I had mine replaced at no cost at 57 000 miles. mine is 07.
of course it can be DYId. you up for it? e.g., there's no gasket, only special compound they use instead.
we use Greg's Japanese instead here, they are chain shops and cost significantly less.
96 000 km.
ukrkoz is offline   Reply With Quote
Old 09-08-2011, 05:01 AM   #3 (permalink)
My car has 98,000 miles on it. I am up for a DIY.
Old 09-08-2011, 09:38 AM   #4 (permalink)
High Desert Hybrids, LLC
View Jennie_Eilerts's Photo Gallery
Presumably you are talking engine water pump? It is just like any other front drive, transverse mounted car. There is not enough room to work, but somehow it is possible to get the job done.
If you don't have a tool to hold the pulley, leave the belt on and use whatever you have at hand (screwdriver etc) to break the pulley bolts loose. Permatex makes a good water pump/thermostat housing sealer, if you don't use the Toyota proprietary stuff. Finally, we also use an AirLift to fill the system up with coolant in order to avoid problems with cooling system airlock. Otherwise, you have to fill up the system to the extent possible, run the engine until it is hot, let it cool, fill it again, and potentially repeat 1-2 more times to get all the air out.
You can only get Super Long Life Coolant from a dealer parts counter, at least that is true in the US as far as I can tell.
Jennie_Eilerts is offline   Reply With Quote
Old 09-08-2011, 10:26 AM   #5 (permalink)
ukrkoz's Avatar
pity. Prius had recall on HV water pumps. I went into regular Camry forum, pages of those pumps failing, not a sneeze from Toyota.
John, estimate on repair is around $350 non-dealer shop. If I were you... now, you in Canada, right? price might be different. shop around, buddy.
Old 09-20-2011, 06:34 PM   #6 (permalink)
How do I check whether there is indeed a water pump leak?
Old 09-20-2011, 09:00 PM   #7 (permalink)
ukrkoz's Avatar
well, firstly, coolant level will be dropping; 2ndly, look for a reddish beard all over the engine front. pullies, and such.
Old 09-20-2011, 09:00 PM   #8 (permalink)
ukrkoz's Avatar
Old 10-18-2011, 04:03 PM   #9 (permalink)
View mdixon's Photo Gallery
2007 Camry water pump
I have a 2007 Camry Hybrid. About 3 months ago I went in to my dealer to get my oil changed and find out where a "leak" is coming from. They come back to tell me my water pump is gone. They change it out. I go back in today to get my oil changed. They come to tell me I need a water pump. I almost come unglued!!! I told him I just had it replaced! He went back out to the garage to "recheck it", he come back to say it was ok. I have 139,000 miles on my car. I would love to know if they're is a water pump issue with the camrys and what is the warranty on the replacement. I have been having issues with headlight bulbs burning out. The past year I have probably went through a dozen bulbs, both high and low beam. The man at the auto parts store says it is because I touched thebulb with my bare hand. The folks at the Toyota shop says it is because I didn't get Toyota bulbs. Any opinions???
mdixon is offline   Reply With Quote
Old 10-18-2011, 06:10 PM   #10 (permalink)
When I took my 2008 TCH in for inspection, the Meadowvale Toyota dealership in Mississauga ON Canada told me that I had a coolant pump leak that could become worse.
To check, I topped up the coolant reservoir and found that the level is not changing. This indicates that the dealership was lying through their teeth.
You would be lucky if you can get a honest Toyota dealer. I have found it better to find a decent local mechanic who would at least prove to you if something is wrong.
Old 10-18-2011, 09:31 PM   #11 (permalink)
ukrkoz's Avatar
rest at peace. you have no warranty left on your car.
yes, you are not supposed to touch halogen bulbs with bear skin. yes, dealership is very likely right too, this computer on four wheels wants stuff its way or freeway. also, very likely, you have short somewhere, causing bulbs to overload and burn.
just to make you feel better, my Silverado toasts headlight bulbs every 6-8 mths. I am used to it.
The Following User Says Thank You to ukrkoz For This Useful Post:
mdixon (10-19-2011)
Old 10-19-2011, 02:41 AM   #12 (permalink)
The part about about the warranty, I was referring to the water pump they just put on.
Old 10-19-2011, 09:31 AM   #13 (permalink)
Part should come with its own warranty, I would think. Like with the car battery when you replace you get a 2 or 3 year warranty.
The Following User Says Thank You to johnjan For This Useful Post:
mdixon (10-19-2011)
Old 10-19-2011, 08:11 PM   #14 (permalink)
ukrkoz's Avatar
replacement pumps are 1 year warranty from dealer.
mdixon (10-19-2011)
Old 10-24-2011, 03:37 PM   #15 (permalink)
View andym1978's Photo Gallery
Since the pump is outside the engine (compared to earlier Camrys with pump integrated into timing belt system), this seems to be a good DIY project for a fairly handy person. It would likely not exceed a day's work. That would cut the cost at least half.
andym1978 is offline   Reply With Quote
