Check Hybrid System Light! Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2011, 06:07 PM   #1 (permalink)
Gameroom cash: $120300
View johnjan's Photo Gallery
This hybrid was purchased from Philadelphia, USA in January 2011. It had 78926 miles on it.
Today it is at 100700 miles.
And today this car gave problems for the first time while coming down on one of the main streets of Toronto (University Avenue). There was a Check Hybrid System warning on the dash and the check engine light was also on. I was doing approximately 10 mph and it was stop and go traffic.
Right thereafter I went onto the highway - Gardiner Expressway West. The car would not go above 40 km/hour. This was dangerous as cars behind me started honking and swerving wildly. Fortunately I could find a safe spot to stop the car at the fork of the ON Ramp to Spadina Avenue. Meanwhile the check VSC warning came on. I turned the engine off. Turned it back on and off two times and the warning was still there. After 15 minutes while waiting for the tow truck, I turned the engine on and the warning lights had gone. Not wanting to take on risk on one of the busiest highways of the world, I had the car towed to a dealer in Mississauga.
They had no clue what was going on since there was no warning light present for them to diagnose.
THIS IS A SAFETY ISSUE.
Anyone as any ideas to offer?
johnjan is offline   Reply With Quote
Old 10-05-2011, 08:37 PM   #2 (permalink)
ukrkoz's Avatar
Gameroom cash: $189750
View ukrkoz's Photo Gallery
scratching my head. just to make sure, miles or kilometers? of course, it was bought in the USA.. but then you are in Ca.
I do not believe anyone will offer you a quick fix magic. It's the dreaded HSD problem. I can only raise my hands and wonder, how in the world does this happen right after 100 000 HSD warranty ends?
You won't fix it yourself. It requires proprietary s/w and equipment to scope and diagnose. We have 6 states here, CARB states, that have 150 000 miles HSD warranty. Unless you have similar in yours, you out of luck, brother. I am VERY SORRY.
My - hopeful - wild guess is your HSD battery got undercharged in stop and go traffic and threw a code on you. I am HOPING that was the case. Otherwise, read above.
ukrkoz is offline   Reply With Quote
Old 10-06-2011, 04:09 AM   #3 (permalink)
Thanks, ukrkoz. I use mph and kph interchangeably.
I have written to Toyota Motor Corp and we will see.
Old 10-06-2011, 12:50 PM   #4 (permalink)
ukrkoz's Avatar
either way, you appear to be right out of warranty. sorry, john, it looks like you had a pass of bad luck...
I am pretty positive there was at least one more member here or at another TCH forum, that had very similar issue, and it went away. he was also stuck in traffic, and battery went low, then all this wonderful lights display came about.
like I said - might have been just low charge and battery started havoc. personally - in case like this, I start scratching my head and looking at replacements. this thing will cost you arm and leg in HSD repairs.
Old 10-09-2011, 01:40 PM   #5 (permalink)
View WhiteSands's Photo Gallery
Had you filled you gas tank before the check engine lamp lit. I have read, a not fully tightened gas-cap can cause a warning light to come on. If toyota can't find anything wrong, you might consider replacing the fuel cap (from your toyota dealer) as a preventive measure.
WhiteSands is offline   Reply With Quote
Old 10-09-2011, 02:31 PM   #6 (permalink)
|Virus|'s Avatar
View |Virus|'s Photo Gallery
Canada
Good point, it does say on the fuel tank to make sure you hear the ticks or else it will activate the check engine light. Hope it works out well!
|Virus| is online now   Reply With Quote
Old 10-10-2011, 07:18 AM   #7 (permalink)
Gas tank was filled a couple of days prior to the incident. It was exactly 200 miles prior to this warning showing up.
Old 10-10-2011, 07:53 AM   #8 (permalink)
I doubt a not-tightened gas cap would be your problem. Most seem to have the light come on not many miles after filling the tank.
Old 10-10-2011, 08:49 PM   #9 (permalink)
ukrkoz's Avatar
yeah, folks, let him be. Don't confuse CEL(gas cap code) light with VSC and HSD warning lights. there's BIG difference between them.
Old 10-11-2011, 07:37 PM   #10 (permalink)
This is the reply I got back from Toyota:
Dear Jxxxxxxxxxxxxxxxxx,
Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
We apologize for the concerns you are having with your Camry Hybrid. Because we cannot inspect your vehicle, we recommend contacting your local Toyota dealership in Canada for inspection.
You may also contact Toyota Canada for further assistance with your inquiry.
Toyota Canada, Inc.
1 Toyota Place
Scarborough, ON
Canada M1H 1H9
888-869-6828
www.toyota.ca
We have documented your comments at our National Headquarters under case reference number 1110xxxxxx.
Sincerely,
Txxxx Mxxxxx
Toyota Customer Experience
Old 10-12-2011, 04:03 AM   #11 (permalink)
[QUOTE=johnjan;3679623]This hybrid was purchased from Philadelphia, USA in January 2011. It had 78926 miles on it.
And today this car gave problems for the first time while coming down on one of the main streets of Toronto (University Avenue). There was a Check Hybrid System warning on the dash and the check engine light was also on. I was doing approximately 10 mph and it was stop and go traffic. [QUOTE]
I did more internet searching. I found a similar high mileage incident that was caused by a faulty coil over plug. Each spark plug in the TCH has a small ignition coil over it so the TCH don't use spark plug wires. The coil is fired from the ECM. (electronic control module) The tech info it was said, to remove each coil wire at the coil and unplug at the ECM. Check each for shorts or crosses in the wiring out to each coil. Another check point is to make sure each coil wire is plugged fully onto the ECM.
No doubt Toyota knows about this type of trouble shooting. Toyota also has a tech center were local toyota dealer techs can call for advise on hard to find troubles.
My thinking it could possibly be a single defective sensor which they are many. A sensor to me, once bad would need replacing. I doubt any sensor would ever become intermittent. To top that any bad sensor should give a trouble code.
