Coolant reservoir for engine is nearly empty! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-12-2011, 07:15 PM   #1 (permalink)
Gameroom cash: $120300
View johnjan's Photo Gallery
My 2008 TCH has the coolant reservoir for engine nearly empty. Is this supposed to be full?
It is Item #11 in the image.
johnjan is offline   Reply With Quote
Old 10-13-2011, 10:33 AM   #2 (permalink)
View regztfen's Photo Gallery
Anti-freeze
I think mine has a minimum and maximum line on it.
regztfen is offline   Reply With Quote
Old 10-13-2011, 11:56 AM   #3 (permalink)
View andym1978's Photo Gallery
I ran into the same issue 2 years ago (2007 model). Checked it randomly, and it was near bottom. It turned out that my water pump was leaking (only 20k miles) and was replaced under warranty. Check for pinkish powder around the area of your belts. If you see that, then you need a new water pump. For now, make sure you top it off with some new coolant and/or distilled water.
andym1978 is offline   Reply With Quote
Old 10-13-2011, 07:39 PM   #4 (permalink)
ukrkoz's Avatar
Gameroom cash: $189750
View ukrkoz's Photo Gallery
Water pump!!!!!
ukrkoz is offline   Reply With Quote
Old 10-13-2011, 07:41 PM   #5 (permalink)
ukrkoz's Avatar
oh, just to make it clear. level is not supposed to move. ever since they replaced mine, it sits at same mark like glued.
Old 10-16-2011, 07:25 AM   #6 (permalink)
Today I filled in the coolant reservoir. Accidentally overfilled it and used a fine tube to drain it to the 'F' level.
I will be checking back upon this level in the near future to figure out if there is anything wrong with the coolant pump.
There are no pink powdery marks in the pulleys area.
Old 10-16-2011, 09:41 AM   #7 (permalink)
ukrkoz's Avatar
not gonna get any on pulleys. they toss coolant droplets all over the engine when they spin.
pending how many miles you have left to reach 60 000 warranty mark, you might be taking chances with "wait and observe" approach.
look up my posts, back in time I posted a few pics of what it looks like. Maybe it's not pump. many other reasons are plausible. But level should stay as is.
Old 10-17-2011, 04:18 PM   #8 (permalink)
My TCH is at 101000 miles. Checked the coolant level after 130 miles and ditto - no movement at all. Will continue monitoring it.
Old 10-27-2011, 07:55 PM   #9 (permalink)
View Pipemajor's Photo Gallery
Water pump on our '07 TCH failed @ 20k miles. Replaced under warranty by dealer.
Our '10 TCH is just over 20k miles and so far, so good.
'10 TCH, Magnetic Grey Metallic, Moonroof, Heated Leather and NAV
'92 LE I4, 165k original miles, Silver Taupe Metallic, Moonroof, ABS
Pipemajor is offline   Reply With Quote
