There's no EV Drive Mode button so no you can't control or "force" the engine to shut off. However, you can try coming to a complete stop instead of crawling in traffic and let the engine shut off on its own.
What I don't understand is the 38mph limit.. The engine is off below that (if all parameters are met) but yet you mention that you want to go above 38mph so that the engine will turn off (I'm guessing you're thinking because you never cross that threshold, the engine stay on and then turn off when you drop below the threshold again???)
Either way, with cooler weather, it'll take longer for the engine to shut off (longer warm up time and you requesting heat).
With the Gen 2 Prius, after a cold start and driving for a while, you'd have to come to a complete stop to let the engine shut off before the engine will shut off while in motion (even if it's already warmed by that time). In the Gen 3, the engine will shut off in motion once it's warmed up so they've changed the programming. Now the TCH was introduced somewhere in between so I don't know if it uses the old programming or not but if that's the case, follow what I said in the first paragraph. Come to a complete stop, let the engine shut off and then you shuld be good.
2010 Prius Technology Package (Cdn)
OEM Cargo Mat, OEM All-Weather Mat, LED ext/int lights, 5000K HID, OEM Fogs, Euro Mudguards
