I have an odd short or loose connection that I cannot find a solution for. I have no lighting on the steering wheel controls, no background lighting on the climate control cluster, and a flickering background light on the radio. The radio also intermittently cuts off and comes back on a second later. Any suggestions??
As far as the radio intermittently cutting out, does it do this when a CD is in the player? I once had a car that had a similar problem. I diagnosed it as a weak CD insertion switch which would occasionally glitch when going over a bump, resulting in the system momentarily being tricked into believing someone had just inserted a CD. The solution was to keep a CD in the player at all times.
As far as the blinking lights, well, that's just plain spooky!
Thankfully, I did fix this issue and it was a simple solution....a fuse. Interesting that nothing seemed to stop functioning except SOME of the dimming in the car. Just the 7.5A Panel fuse was blown!
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
587K members
Since 2001
