Hybrid and Cams Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2005, 01:14 AM   #1 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
Correct me if i'm worng here but, the 5SFE is a DOHC but the exhaust cam is actuated by the intake cam via some kind of scissor valve, jack, thingy.
The 3SGTE is True DOHC with each cam actuated seperately.
So, if i were to use a 3SGTE Head on my 5SFE would that enable me to use 3SGTE cams as well?
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 09-02-2005, 02:35 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Correct.
Theres only one camgear (on the intake cam) and the intake cam drives the exhaust cam.
Yes.
You use the cams for that cylinder head.
Don't use the cams from a 5S-FE. They wouldn't work anyways.
"Skoolin' the unlearned!"
Old 09-02-2005, 02:48 AM   #3 (permalink)
5SFE
Lord_Anarchy's Avatar
View Lord_Anarchy's Photo Gallery
will that just bolt right up? Any changes to the timing?
Lord_Anarchy is offline   Reply With Quote
Old 09-02-2005, 07:30 AM   #4 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
it not just drop and go.
you have to match years for the engines. and change the ecu and harnest. search around the site lots of info from wrath and what not.
^ and leaving it that way!
Old 09-02-2005, 12:38 PM   #5 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
so if i change the head i've got to change the ECU and wiring harness? Why exactly do i need to mess with the harness?
Old 09-02-2005, 12:50 PM   #6 (permalink)
The Other White Meat
terrastrife's Avatar
did you search yet?
terrastrife is offline   Reply With Quote
Old 09-02-2005, 05:57 PM   #7 (permalink)
Grenaded piston
88 LE's Avatar
The sensors, ignition system, wiring, etc... are different.
You can't just bolt up the cylinder head, plug stuff in, and expect it to work.
Old 09-02-2005, 08:17 PM   #8 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $261475
It'll work just fine as a paperweight....
-Charlie
