Re: Broken timing belt on my 90 4runner
Thanks Clyde, I'm the shade tree guy :-(. I'm not quite sure what you meant
by a full rotation off. The two cam on top is a bigger gear, and the crank
is a smaller gear on bottom. The bottom gear has to rotate a few times
before the top cam gear can line up. I checked the chilton repair manual and
it didn't say anything about the possibility of a full rotation off. Can you
explain what you mean?
I hope you're right about the valves not damaged, because it will be a
nightmare for me. Are you a mechanic expert? How do you check if the values
are ok?
Thanks in advance.
-don
Clyde Hathaway wrote:[color=blue]
>I am not sure, but sounds like the marks may be aligned, but a full rotation
>off. In other words, the engine is trying to fire while the valves are
>open. The valves in this engine are not usually damaged when the belt
>breaks. Did toyota put the belt in - - or a shade tree guy?
>Hope this helps,
>Clyde
>[color=green]
>> I had a broken timing belt while driving on a freeway. I had the timing belt
>> replaced and the timing marks set correctly, the engine cranks and try to[/color]
>[quoted text clipped - 6 lines][color=green]
>> Thanks,
>> -don[/color][/color]
