Troubleshooting Distributor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2005, 05:06 PM   #1 (permalink)
View jefe's Photo Gallery
Quick, general question:
My ignition coil looks "beat up" and tested out of spec, but I do get a spark from it when I turn the ignition on.
Could my car not be starting because of a bad coil, even though I get a spark?
Thanks!
jefe is offline   Reply With Quote
Old 10-04-2005, 05:21 PM   #2 (permalink)
Mad Aussie Toy Owner
toyboyracer's Avatar
View toyboyracer's Photo Gallery
Australia
To quote Lionel Hutz Attourney @ Law
"Now.... There's a spark....and... there's a SPARK !"
So it can be there & weak, but not enuff for ignition.
Some people are like slinkies,,,,Not really good for anything,,,,
But they still bring a smile to your face when you push them down a flight of stairs
Unfortunately evreyone has an opinion [q] ME [/q]
"The Thunder From Down Under"
http://www.camcrew.com.au
toyboyracer is offline   Reply With Quote
Old 10-04-2005, 05:24 PM   #3 (permalink)
It was occasionally not starting, until I tried to fix it. Now it won't start at all.
I replaced the rotor and dist cover. When I checked for a spark with the cover off, there was a pretty good spark from the coil, and it was arcing to the base of the coil and elswhere on the innards of the dist. (Not sure where it should spark to when the cover is off.)
Old 10-04-2005, 05:33 PM   #4 (permalink)
Australia
A loooooooong time ago when I was 18 and did my ummmm 1st "tune" I accidently switched 2 spark plug leads around on the dizzy.... Could be de ja vu?
BTW, you DIDN'T take the wires off the coil did you?
50% of people put them back on the WRONG WAY !
Old 10-04-2005, 05:37 PM   #5 (permalink)
Gameroom cash: $304355
If it's arcing to the base of the distributor you have a crack in the coil itself and it is grounding itself out, causing a weak or no spark condition. Replace the coil and it should start right up. You don't say what year your car is but this is a common problem on a generation 2 (87-91) Camry, although it can happen to any of the first 3 generations (those generations that used a distributor).
Mike
Old 10-04-2005, 05:41 PM   #6 (permalink)
Thanks Mike. I just overnight ordered a new coil. I'll let you know how it works out. Thanks too, ToyBoy
Old 10-05-2005, 02:13 PM   #7 (permalink)
jefe,
About 5 or 6 years ago I replaced the coil in my niece's 91 Camry with the 3SFE 4 cylinder engine. Her problem was more of a misfire in damp weather. Anyway, I was able to purchase a Borg Warner (aftermarket coil) in stock at Pep Boys for about $40, just in case you didn't want to wait. That did solve her problem and the car is still running perfectly today. The dealer wanted to replace here whole distributor for $600.
Mike
Old 10-09-2005, 01:23 PM   #8 (permalink)
Ultimately, it turned out to be the coil. New coil did the trick. Thanks for the input!
