rear power window - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2005, 10:31 PM   #1 (permalink)
View land5150's Photo Gallery
Question rear power window
I have a 92 camry le. when I bought it used i was told neither back windows worked. Not a problem, dont really need them. However I ended up with one broken out. When the window was replaced, the guy pushed the down button and the window went halfway down and will not come up. Is there a way to get this window up and leave it up. I do not need the back windows to operate, just to be closed.
land5150 is offline   Reply With Quote
Old 10-04-2005, 10:48 PM   #2 (permalink)
1B2 V6 Clean!
Camon19z's Avatar
View Camon19z's Photo Gallery
It might not only be the window, it can also be the window switch aswell
Camon19z is offline   Reply With Quote
Old 10-05-2005, 10:30 AM   #3 (permalink)
View TriumphGT6's Photo Gallery
I fix power windows for people all the time because I know how to do it. I'm gonna be nice and give you the info on how to do it yourself.
Step 1: Disattach Door panel, check for all screws, fasteners, etc. Be sure they're all out.
Step 2: Gently remove the switch panel, use a flat head screwdriver, with a towel over it to not screw up your panel.
Step 3: Remove the wiring from the switch, and place the switch aside.
Step 4: Take the door panel off gently, if you have to use force check to see that it isn't wires or screws, then take it off. Some doors use clips that just fight you. In other words, be careful.
Step 5: Remove the sound and weather barrier, its plastic and sometimes foam.
Step 6: Check to see what is wrong with the motor and regulator. If the motor is messed up, buy a new one, if the regulator is messed up, just buy a set of a motor & regulator on eBay (dirt cheap).
Step 7: If you haven't already, buy a manual for your car at Autozone and see the specific procedure for replacing and installing the motor and regulator assembly.
Step 8: If you don't want to fix the motor, you can remove it and the regulator, push the window all the way up, and tape or epoxy it into permanently up.
Good Luck, but I'd try to fix the windows up/down functionality too.
TriumphGT6 is offline   Reply With Quote
Old 10-05-2005, 11:39 AM   #4 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397085
View RningOnFumes's Photo Gallery
^^ what he said .
i don't know about you but if i were to go in that deep, i might as well make the window fuctional especially if he said the parts could be had for cheap
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
