transmission fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2005, 11:56 AM   #1 (permalink)
View The Black Camry's Photo Gallery
transmission fluid
how much trans fluid do i need in my 1990 camry , manual , 4cyl ? and is there a specific kind that i need ?
The Black Camry is offline   Reply With Quote
Old 10-05-2005, 05:59 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
If you drain the fluid from the pan you'll probably drop 2 quarts. Buy 3 in case you need more. I would use MAX Life fluid for older cars but there are many options out there. If you haven't changed the fluid in over 50,000 miles I would be very hesitant to suggest that you change the fluid at all.
Kep
Old 10-06-2005, 11:53 AM   #3 (permalink)
but what kind exactly do i need
Old 10-06-2005, 09:10 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
I believe it's 75W-90
2007 Camry 2.4L 5M
Old 10-07-2005, 05:49 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Dexron II ATF. IE: auto tranny fluid.
I know its weird since you have a manual tranny, but thats what it uses.
http://www.autozone.com/servlet/UiBr...3d8013de6f.jsp
"Skoolin' the unlearned!"
Old 10-07-2005, 11:55 AM   #6 (permalink)
thanks!
Old 10-07-2005, 12:25 PM   #7 (permalink)
Kep
Kep's Avatar
Wow, I messed up on that one. I didn't notice the "manual". Manual transmission on a 3sfe engine is supposed to drain out about 2.7 US quarts. You'll still be good if you got 3 quarts as suggested but you'll use most of it. If you have a different engine repost.
I hate it when I do that....
Kep
