NGK Iridium plugs are the best!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2005, 12:54 PM   #1 (permalink)
View AVL92CAMRY's Photo Gallery
Thumbs up NGK Iridium plugs are the best!!
Just an observation for those who may be changing their spark plugs soon. I changed plugs about a 2 months ago on my '92 5s-fe Cam. Changed from Denso platinum plugs with about 80k miles on them to NGK Iridium Laser plugs [EDIT$28/4)] and what a difference!
Smoother accel and idle, and I have gained 2mpg on every fillup since!
Also had my emissions tested for fun at the Alternative Energy Fair and at idle I was only one point below a 2004 Honda Civic across the board!
I am definately a convert to the Iridium plugs.
Karl
1992 Camry, 5S-FE, 5sp, Eibach Prokit, KYB GR-2, Toyo Proxes TPT, 210,000miles
AVL92CAMRY is offline   Reply With Quote
Old 10-05-2005, 01:20 PM   #2 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
I use NGK in the turbo cam... and i don't plan on changing
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
Old 10-05-2005, 01:23 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
and plain copper would would be cooler and spark better!
wow!
but yeah if you want hi mileage plugs use those.
terrastrife is offline   Reply With Quote
Old 10-05-2005, 01:24 PM   #4 (permalink)
View AutoBox's Photo Gallery
^ you get what you pay for w/plugs high quality iridium
AutoBox is offline   Reply With Quote
Old 10-05-2005, 01:41 PM   #5 (permalink)
View cam01speak's Photo Gallery
Where did you buy them? I find it cheaper in advance autoparts ($6.98/ea) for Iridium IX Plug; BKR6EIX-11; DOHC;
newb
cam01speak is offline   Reply With Quote
Old 10-05-2005, 01:43 PM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
No Bowdown here.
NGK Coppers have always run better in my supra.
Old 10-05-2005, 01:53 PM   #7 (permalink)
Originally Posted by Jeeves
No Bowdown here.
thats becuase copper are cooler rated and conducts better.
the only reason that you do not use cheaper copper plugs is if you absoluteley hate changing the rear 3 on a fwd v6
but then again, with plats or iridiums, if they get dirty they loose power whatever and you should take them out and check gap and clean em, but then you may as well put in brand new copper plugs in.
Old 10-05-2005, 02:11 PM   #8 (permalink)
Hi.
View mystickid's Photo Gallery
Does your cars mileage play a role in getting new sparkplugs?
I wanna do a tune-up and change my sparkplugs on my 60K 98' Camry.
Should i buy NGK Iridium or copper???
mystickid is offline   Reply With Quote
Old 10-05-2005, 02:14 PM   #9 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
Denso Iridiums are actually better plugs. They use a finer tip and are U-grooved.
The NGK plugs are quite nice though, it's what I'm running now. When I get some cash to spare I plan to convert to the Denso Iridiums.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 10-06-2005, 01:59 AM   #10 (permalink)
View ToyotaGuy50's Photo Gallery
As long a s the plug says denso or ngk in a Toyota it usually runs great.
Have you considered that the plugs you replaced were worn out and the new set of
quality plugs made the differance? I'm willing to bet if you put a new set of identical plugs
(denso platinums) your results would be the same.
I have tried all kinds of plugs (iriridiums, splitfires whatever the current rage is) and I've found aprak plug is pretty much a sparkolug since now al ignitions are precise, high power electronics. Sparkplug design made a difference only back in the points/condensor/coil days.Like I said as long as they are quality plugs in the right heat range for your motor it will run great. Irridium or no irridium.
BTW I've been running denso irridiums for the last 10k miles. No difference from the original plugs. (99 camry 5SFE 75k miles on the clock)
ToyotaGuy50 is offline   Reply With Quote
Old 10-06-2005, 02:07 AM   #11 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
Originally Posted by CrawlingEye
Denso Iridiums something something something
but they arent jdm enough
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 10-06-2005, 02:15 AM   #12 (permalink)
View leasaunce's Photo Gallery
BTW when should you change the sprak plugs?? every 10,000km ?
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 10-06-2005, 03:39 AM   #13 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
I'm tossing up wether to change out my NGK Iridiums in my car for some plain NGK copper ones. Everytime I put a set of Iridiums in (yes this is my second set!!) the car runs well for the first few hundred miles, but then it starts too loose its performance. I'm pretty sure its plug related because when i change them, it runs better for a while. Maybe the cooler, better sparking copper ones would be better. Only thing is I have to change them more often :P
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 10-06-2005, 08:47 AM   #14 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
how much do the copper ones for a 5sfe go for?
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 10-06-2005, 09:32 AM   #15 (permalink)
cam01speak: I got mine at Advance too. I forgot I had a tube of anti-seize on that purchase too so the plugs were only $28+ tax.
ToyotaGuy50: Your probably right. If I had put any new NGK or Denso plugs in I would have noticed inprovements considering my plats were about 20k overdue. But I do think that the iridium plugs would give a better flame kernel and therefore cleaner emmisions and a more complete ignition of the mixture.
Anyway the plugs work well for my Cam and I will stick with them. I may give the NGK coppers a try though just for a personal comparison.
Karl
