As some of you may know, I'm having a head built for my 5S. Where the build stands at the moment is that I still need to purchase valve springs, which we've already found a source for. We're going to need to order new buckets too, because the head spit 2 shims while the cams were being hand turned. We've sourced a shimless bucket conversion from a JDM toyota. I do not have specs for it as my builder (ChrisK of ) spoke with a Toyota rep which returned us with the buckets we required (28mm bucket, either shim under or shimless... it's a small bucket pre-'93 5S head). The springs we're planning to run are from TEDcomponents and are designed for a 4AGE 16 valve, they're rated at 65lbs seat pressure and 250lbs open pressure for the single spring kit and 66lbs seat pressure and 300lbs open pressure for the dual spring kit... I'm undecided on which set of springs I may go with, the dual kit may be an overkill but the price difference is quite small so I may just go with the dual.
As for what's currently completed with the head?
-Fully ported and polished
-1.5mm oversized valves (32mm valve size)
-Custom cams using rav4 3sfe cores ground to .370/.390 lift and 220/228 duration @.050"
-Milled to 10-1 CR and decked
-Radiused valve job
Now on with the fun part:
The head's flowbench results are 265CFM and 315 ft/sec velocity. I'm extremely happy with these results. If everything works out well, this should put down some very respectable numbers.
What else is in the works for the car?
-Possibly a Megasquirt 2 (or another form of EMS, I haven't really had time to look through the options yet)
-s54 tranny swap with a CM/findanza flywheel, complete with all speedsource accessories and a clutch/pressure plate kit
-Chamfered crankshaft journals
-Machined crankshaft to accept 3sgte (factory forged) rods
-Custom CP high compression pistons (looking at somewhere between 11-1 or 12-1 final CR)
-Current Gen Camry oil pump (flows better than a 3sgte pump)
I'm hoping to have the head on and running within a couple months (we're going to be waiting for the buckets to be shipped from japan a couple weeks yet), then I'll post some dyno results, providing I can still find an open track in a couple months I'll post track results as well.
HUGE props to ChrisK at Engine Logics in Houston Texas for all the machine work on the head, Ken from OregonCamshaft for the rav4 3sfe cam source and grinds and Richard from TED Components for the help with valve springs and so forth.
http://www.enginelogics.com
http://www.oregoncamshaft.com
http://www.tedcomponents.com
