Oil on spark plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2005, 06:07 PM   #1 (permalink)
View benkillin's Photo Gallery
Oil on spark plugs
I went to change my spark plugs on my 1990 Toyota Camry delux 4
cylinder, and when I went to replace the spark plug, I saw quite a bit
of oil on the old plug. I checked each one, and they all had oil on them, but not as much as the first one.
I think this might be a piston ring or a valve
seal, what do you think is causing this and how much do you think it
will cost for a mechanic to fix it?
benkillin is offline   Reply With Quote
Old 10-05-2005, 08:31 PM   #2 (permalink)
ultimate lurker
View 88hawcam's Photo Gallery
Is the oil on the electrodes of the plug,(The section inside the combustion chamber.) or is it towards the other end of the plugs(Where the plug boot goes over it)?
E.T.Oka
88hawcam is offline   Reply With Quote
Old 10-05-2005, 10:02 PM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
yeah need to know where the oil is located on the plug. If the plug tubes are leaking it iwll be on the outside where the boot goes over the plug. If it is on the electrode taht actually goes into the combustion chamber then it will be seals or rings.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 10-06-2005, 01:27 AM   #4 (permalink)
View ToyotaGuy50's Photo Gallery
If you know how to read spark plugs and you say oil on plug #1 I would assume that you took a compression test or leak down test and you would know whether it's valve seals or rings. (99.9% of the time it's valve seals very common)
If it is on the exterior of the plug your spark plug tube o-rings and/or valve gasket is leaking. (also very common)
ToyotaGuy50 is offline   Reply With Quote
