AC panel quesytion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2005, 06:01 PM   #1 (permalink)
View Exlax's Photo Gallery
4th Generation AC panel quesytion
Hey everyone i am new here, and i have a 1998 toyota camry le with about 9300 miles on it. When i have my headlights on everthing lights up exept for the ac panel, and the gauges to control the heat/ac on or off, i was wondering if you guys had any guides on how to replace these bulbs, or if it was a fuse problem. Thanks ALot.
Exlax is offline   Reply With Quote
Old 10-06-2005, 06:28 PM   #2 (permalink)
View leasaunce's Photo Gallery
hahaha..... im having the same problem as you are matey!
Do some search & you'll find heaps of info. theres a guy called "SnakeyeS" he's the man of this subject!
http://www.toyotanation.com/forum/t97347.html
http://www.toyotanation.com/forum/t96042.html
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 10-06-2005, 06:33 PM   #3 (permalink)
But i need infor on the HVAC area because i dotn have a factory head unit in it ne more.
Old 10-06-2005, 06:37 PM   #4 (permalink)
according to "Snakeyes" he told me there are 2 #74 Bulbs and couple more of SMD lights for the AC & Defrost Button.
my AC light is gone, so i gotta replace them sometimes next week. Just dont have the time to do it and plus Its getting HOT in Sydney. so ill do it when its much cooler....
EDIT: http://www.toyotanation.com/forum/t98587-2.html <<<---- Thats what you need!
Old 10-06-2005, 08:06 PM   #5 (permalink)
Any info on removing that piece and getting to the lights, thanks for your replies they are helpful!
Old 10-06-2005, 08:08 PM   #6 (permalink)
im not sure on how to remove the AC panel myself. i think there are couple of clips surrounding the area.
i'll post them in couple of days, if you dont mind waiting.
Old 10-06-2005, 09:25 PM   #7 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
gen 4 HVAC panel is removed by first popping off the main console trims which is held on by 4 plastic clips. Pry the trim with a flat head screwdriver with tape over the tip to prevent damage to your dash. The trim pulls straight out.
Next you'll see 4 screws holding the HVAC to the dashboard. Undo those. Next pull the 3 large ajustment knobs off my pulling straight towards you. Also pull of the small knob that dictates the fresh/recirculated air. There should be 1 screw behind each of the 3 adjustment knobs. Undo these. Undo the A/C and defrost pushbuttons from the plastic HVAC casing. Pull the plastic HVAC casing off and you'll see two(2) #74 blubs with green condoms on them.
The A/C and defrost use seperate bulbs. LEASAUNCE: THESE BULBS ARE NOT SMD LEDS. Each pushbutton uses a small bulb in the button that is not easily replacable as it is small and attached to a plastic base.
Before you try anything, pound you first around the area a few times. THe bulb contacts in this are a shitty and come loose very easily.
Bulb on the left is the A/C bulb. Bulb on the right is a #74. You can see its way smaller:
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 10-07-2005, 06:17 AM   #8 (permalink)
so what do you called that small bulb then?? ANYONE??
Old 03-09-2006, 04:57 PM   #9 (permalink)
View hazedlife's Photo Gallery
so.. whats the bulb type for the AC button?
sorry for bring this post back from the dead...
hazedlife is offline   Reply With Quote
Old 03-09-2006, 05:07 PM   #10 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
You can buy them from the dealer. The Previa uses the same one. The only one that I think you cant repalce is the defroster, you have to buy a new switch.
drunken_panda is offline   Reply With Quote
Old 03-09-2006, 07:49 PM   #11 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
lol my right bulb is loose, sometimes i gotta smak the unit to have it light up...haha
maybe i'll try taking it apart. hehe
nodrogkam is offline   Reply With Quote
