help! alternator problem. (i think) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2005, 03:40 PM   #1 (permalink)
View Stephademic's Photo Gallery
I'm trying to figure out what is wrong with a 1999 Toyota Camry. When trying to start it, it only clicks. i charged the battery and it worked..but it quickly died again..leading me to believe that it is the alternator.
Is this my problem?
If so, how can I fix it? I want to buy the part and fix it myself if at all possible. Can anyone explain it for me?
Thank y'all so much -
Stephanie
Stephademic is offline   Reply With Quote
Old 10-07-2005, 03:46 PM   #2 (permalink)
View Gary_602Z's Photo Gallery
Charge the battery completely and then have it tested. Check your battery cable connections. You can have your alternator tested also. That way you aren't replacing parts that are not bad.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 10-07-2005, 04:09 PM   #3 (permalink)
View NCGuy68's Photo Gallery
If its the original 1999 battery, more then likely its dying and about to go belly up. If thats the case, replace the battery.
Although its possible - I doubt the alternator is bad.
NCGuy68 is offline   Reply With Quote
Old 10-07-2005, 05:48 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
Fast clicks or a single click?
雄のハヤブサ
Tercel GTS is online now   Reply With Quote
Old 10-07-2005, 05:55 PM   #5 (permalink)
Mad Aussie Toy Owner
toyboyracer's Avatar
View toyboyracer's Photo Gallery
Australia
Battery dead/dying, crap connections on battery/starter motor,
solenoid on starter motor sticking
Some people are like slinkies,,,,Not really good for anything,,,,
But they still bring a smile to your face when you push them down a flight of stairs
Unfortunately evreyone has an opinion [q] ME [/q]
"The Thunder From Down Under"
http://www.camcrew.com.au
toyboyracer is offline   Reply With Quote
Old 10-07-2005, 05:58 PM   #6 (permalink)
The Other White Meat
terrastrife's Avatar
guys.. its clicking, hes got power... does ya readio and lights work?
you may have a sticing soleniod or dead alternator...
terrastrife is offline   Reply With Quote
Old 10-07-2005, 07:31 PM   #7 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
My freinds berretta clicked when his car wasnt getting any gas. And my 90 camry clicked when i had a dead battery.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
