Haynes doesn't show it...need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2005, 02:07 AM   #1 (permalink)
Sleeper-still sleeping
Redline's Avatar
View Redline's Photo Gallery
3rd Generation Haynes doesn't show it...need help
I need help locating the power wire (green) for the "parking light" or "corner lamp"....from the interior. I need to tap into it, but I don't wanna run a wire from the outside (engine bay /headlight area) into the interor, where I need it.
I have a recent pic of some connectors and bundles of wires located in the driver-side footwell (see below). Ignore the yellow circle...sorry for the blurry pic:
Do any of these connectors contain the power wire that I'm looking for? IF SO, which one is it and can I splice an extra wire to tap into it? IF NOT, please point me in the right direction to find the wire.
Thanks in advance....could use the help ASAP!
Redline
2003 4WD XR Matrix
Mods: HID low-beams, Injen CAI, Pioneer mp3 H/U, Tein SS Coilovers, Hella foglights, Corolla TRD STB, TRD 17" alloys w/ General Exclaim UHP, stubby antenna, KVR cross-drilled rotors, 35% tint all-around.
Pending: DIY-fix for front lip kit...
Redline is offline   Reply With Quote
Old 10-08-2005, 02:39 AM   #2 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
Get a logic probe, or a Digital Multi Meter. and stick it in the plastic connector that those wires go into. and test each pin. While testing turn the park lights on and off. I used to have to do this at circuit city all the time when i installed remote starters.
http://www.bulldogsecurity.com/diagrams/diagrams.htm <---thats a link to bulldogs wiring diagrams for remote starts. its the same thing u are looking for
it says on thier site that there is 2 GREEN wires, one for Positive + and one for Negative -
The wire u are looking for is positive and it is located under the fuse box and the wire is going into a plastic white connector.
Hopt this helps
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 10-08-2005, 02:55 AM   #3 (permalink)
Local Rape Machine
View ekim55121's Photo Gallery
when i did my install of my remote start, it says that its a small white plug on the top of the fuse box it has 3 wires in it i think and its the green striped one so be on the look out
ekim55121 is offline   Reply With Quote
Old 10-08-2005, 09:55 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
http://www.toyotanation.com/photos/s...cat/500/page/3
"Skoolin' the unlearned!"
Old 10-08-2005, 10:34 AM   #5 (permalink)
Midship Captain
ModifierMR's Avatar
Originally Posted by 88 LE
that proves what i said is correct....Thank you
すべての日本への私のお悔やみ。
Old 10-09-2005, 06:06 PM   #6 (permalink)
Redline's Avatar
^ and ^^
Sweet! Thanks BrianOwens and 88LE
2003 4WD XR Matrix
