Brake Squeek - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2005, 10:31 AM   #1 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
Gen5 Brake Squeek
Ok, i now have 27,788 miles on my car. And ive noticed for the past month when im in a quite place with my car, the brakes make a quick squeek sound when i take my foot off the brake.
Its really annoying and has been gettin gradually louder. And its ticking me off.
What should i look for on my brakes? what can be causeing this noise? does it need tightening? New pads? Lubracation of some sort?
thanks
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 10-08-2005, 07:14 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
just get ready for new pads DO NOT let them start scraping... that would be pad backing on disc >_<
my brkaes have been squeeking for the last 2 months, still got plenty of stop left in them.
terrastrife is offline   Reply With Quote
Old 10-08-2005, 08:20 PM   #3 (permalink)
View deekay140's Photo Gallery
sounds like the the rear shoes rubbing on the the backing plate when released, see if it does it with the emergency brake.
deekay140 is offline   Reply With Quote
Old 10-08-2005, 08:26 PM   #4 (permalink)
Mad Aussie Toy Owner
toyboyracer's Avatar
View toyboyracer's Photo Gallery
Australia
Sometimes a good blow out with an air compressor gets rid of rear shoe noise
Wear protection from the dust !!
Some people are like slinkies,,,,Not really good for anything,,,,
But they still bring a smile to your face when you push them down a flight of stairs
Unfortunately evreyone has an opinion [q] ME [/q]
"The Thunder From Down Under"
http://www.camcrew.com.au
toyboyracer is offline   Reply With Quote
Old 10-08-2005, 08:32 PM   #5 (permalink)
View Gary_602Z's Photo Gallery
27k? Brakes will squeek! If they are not grinding do not worry about it.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 10-08-2005, 10:05 PM   #6 (permalink)
View steve97's Photo Gallery
Maybe this will help. I had the same sound when I let off of the brakes. It was coming from the rear. I took off each wheels, removed the brake drum, used brake cleaner to wash the surface, then applied brake lube (autozone $2) to six points on each wheel, where the plate of the brake shoe actually touches the backing plate. Look for little marks from the rubbing between the two surfaces. You can pull the shoe off the plate with a small vise grips, or even wedge a large screw driver between, just make an 1/8th on an inch gap and lube it up. After that, no more squeaks.
steve97 is offline   Reply With Quote
Old 10-09-2005, 09:11 PM   #7 (permalink)
View 1200mk's Photo Gallery
had the same shit on my gen 5 v6 se.... changed the front brake pads today and the squeaking was due to the right brake pad worn all the way down the metal!
Brake pads are designed to squeak when they are supposed to be changed (just like a baby crying).
o btw i have about 27k on my car too!
the right brake pads were 50% gone but i still changed them and resurfaced my rotors. Total cost was about $60 ($20 for resurfacing and $40 for the kragen ceramic pads).
1200mk is offline   Reply With Quote
Old 10-09-2005, 09:17 PM   #8 (permalink)
Midship Captain
ModifierMR's Avatar
thanks alot i need to get that done when i have money
すべての日本への私のお悔やみ。
Old 10-09-2005, 09:24 PM   #9 (permalink)
View leasaunce's Photo Gallery
sounds like you need new pads.
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 10-09-2005, 09:27 PM   #10 (permalink)
Australia
1200mk, if ONLY ONE SIDE of your pads (1 set) was worn down,
with the OTHER SIDE still with 50% left, you've got a STICKING PISTON
on the WORN OUT side !
If the cars uder Warranty, take it in ASAP & get it fixed before the
SAME thing happens AGAIN !
Old 10-09-2005, 09:37 PM   #11 (permalink)
Midship Captain
ModifierMR's Avatar
my car is under warranty. But just for the record.....how much should a good brake pad have left on it? Cause im gonna check em tommorow. Im sure there isnt much
すべての日本への私のお悔やみ。
Old 10-09-2005, 09:41 PM   #12 (permalink)
Even stevens
Both sides should wear evenly...
How much is actually left there depends on how much you brake,
not on the number of miles you do !
Old 10-09-2005, 10:26 PM   #13 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Take the wheels off and check the brake wear on the pads. Sometimes they squeal because they are dirty not because they are worn. Do not spray with compressed air. The dust contain some stuff you don't want to be breathing in. Get some brake cleaner and spray all over.
2007 Camry 2.4L 5M
Old 10-09-2005, 10:30 PM   #14 (permalink)
Australia Asbestos ?
Touring, here in Oz Asbestos in brake pads/shoes has been OUTLAWED for quite a while, does America still use it in brake components?
Old 10-10-2005, 01:29 AM   #15 (permalink)
hmmm... should i just bring the stock pads to the dealer? will they charge me? they wanted to charge me $50 just to look at them last time.
