Recurring stalling problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2005, 01:10 PM   #1 (permalink)
View loud033's Photo Gallery
USA Recurring stalling problem
Hey Guys,
Looking for a bit of help.My wife drives a 95 camry,4 cyl,has approx 136,000 miles.When starting the car it often dosn't hold the idle,stalls,if she starts it and races it it will hold the idle..Have had the throttle assmbly replaced twice and 1 of the 2 cadallic converters replaced..Tried putting some cleaner in and that seems to help very temporary..The car never really sounds like it has a strong idle..any thoughts of what can be causing this??Is this common for this model?? Thanks ......
loud033 is offline   Reply With Quote
Old 10-08-2005, 01:56 PM   #2 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Replace the ECT sensor yet?
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 10-08-2005, 01:58 PM   #3 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
could be a fuel injection problem/Air intake assembly?
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 10-08-2005, 02:28 PM   #4 (permalink)
View keylogger's Photo Gallery
how much are you idling, maybe your going to low?
Willing to learn from "experienced" tunners. I just need the parts.
keylogger is offline   Reply With Quote
Old 06-06-2006, 07:39 AM   #5 (permalink)
View Pezman04wrx's Photo Gallery
Bump from the dead for the same basic issue on a 96' 4cyl Camry... Sparatic at best, but it definately happens ... On occasion the better half complains that the car dies out upon start-up, or won't start to begin with ... Though I can drive the car for ten days straight and it's perfectly fine, I have experienced the problem once ... Almost seems to be idle related, but 99 of 100 times it's perfectly fine, so I wouldn't say the idle is too low ... Recently troubleshooting has given the Camry a new battery/wires/plugs, and the pro-deal shop injector cleaning ... Any thoughts or possibilities? ... Maybe a link to the IAC valve cleaning or something?
- 04' wrx ... It get's up and goes ...
- 96' Camry ... What it had, got up and went ...
Pezman04wrx is offline   Reply With Quote
Old 06-06-2006, 09:10 PM   #6 (permalink)
Gameroom cash: $304355
I agree with cleaning the idle air control valve. You can do this yourself. Just remove the big tube off the throttle body and get some throttle body cleaner or O2 safe carb cleaner. Spray the cleaner liberally in to the throttle body with the engine off. Have someone hold the gas pedal to the floor for you, so the back side of the throttle valve is exposed for easy cleaning. Now on to the idle air control valve. Inside the base of the throttle body you will see a square or diamond shaped port. Spray liberally in to that port. Let it soak in there for a few minutes. Then put everything back together and start the car. It will be hard to start and will smoke liberally for a few minutes after it starts. You might have to hold your foot to the floor to get it started; this is how you start a flooded engine on a fuel injected car. Once the car starts, take it for a 15 minute ride to clear all the cleaner out of the system.
Drive the car normally for a few days and see if the problem is gone.
Mike
Old 06-07-2006, 07:59 AM   #7 (permalink)
Doctor J's Avatar
Gameroom cash: $261890
View Doctor J's Photo Gallery
Sounds like a vacuum leak
Doctor J is offline   Reply With Quote
Old 06-07-2006, 02:05 PM   #8 (permalink)
Thanks Mike ... I'll give that a shot and see if that rectifies the problem ...
