Under dash neon light install help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2005, 10:05 PM   #1 (permalink)
Aussie Gen4 V6
View therufus's Photo Gallery
4th Generation Under dash neon light install help
I got some cold cathode lights for my birthday for the car. I'm wanting to do something different. I eventually do the boot light thing, but for now I want to put them under the dash so the footwells glow blue when the door opens (or when the interior light is on).
I decided to have a crack at it just then. It took me 15 minutes to find where the fuze was that I blew (why put the interior dome fuse in the engine bay??? ). I had to replace my 7.5amp fuse with a 10 because thats all I have.
Anyway. Any hints on how to do it. I want to connect it to the dome wiring loop. Do I need to use a different strength fuse? Where are the cables I should tap into?
Even though it's illegal for cousins to marry here, I still see Holden drivers on the road!
therufus is offline   Reply With Quote
Old 10-08-2005, 10:37 PM   #2 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
First things first
go pull the 10amp fuse
never NEVER put in a higher rated fuse then it was
how did you go about tapping into the system?
this is slightly more complicated then just splicing in.
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
Old 10-08-2005, 10:41 PM   #3 (permalink)
Aussie Gen4 V6
I haven't spliced anything yet. I tried the neons by taking the globe out of the dome light and holding the contacts together. Everything worked fine.
I tried to find the corresponding plug in the interior fuse box and hooked up the lights by once again, holding the contacts together. It worked okay for a few seconds then stopped. I hooked it to the "door" connection in the fuse box.
Without the fuse in the engine bay I can't remotely lock my car.
Old 10-08-2005, 10:42 PM   #4 (permalink)
How Ya Like Me Now?
heres the thread you want
http://www.toyotanation.com/forum/t94355.html
search next time please
98 V6 XLE
Old 10-08-2005, 10:43 PM   #5 (permalink)
How Ya Like Me Now?
forget about locking your car remotley. If something happended you could fry wires or something. Just lock it and get one asap
98 V6 XLE
Old 10-08-2005, 10:49 PM   #6 (permalink)
Aussie Gen4 V6
Thanks alot. I'll try and work it out.
Old 10-08-2005, 11:05 PM   #7 (permalink)
Aussie Gen4 V6
I'm ordering the relay now.
