transmission oil initial fill and total fill - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2005, 02:15 PM   #1 (permalink)
celica2004's Avatar
View celica2004's Photo Gallery
can any one explain this:
CAPACITIES
--> Automatic Transmission, 3-spd Initial Fill..........2.7 quarts[2][3]
Automatic Transmission, Total Fill
--> 3 speed A131L..........5.8 quarts
whats the difference between initial fill and total fill? I want to change transmission oil and how much should i buy and use?
does total fill means after removing differential fluid also? i am confused...
WTF?
celica2004 is offline   Reply With Quote
Old 10-09-2005, 03:18 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
that's just the drain and fill w/o taking all the fluids out of the torque converter if u were to drain and suck out the TC then u would have to fill it back up the whole way... i don't know about diff fluids.
atobe is online now   Reply With Quote
Old 10-10-2005, 09:00 AM   #3 (permalink)
View basil's Photo Gallery
As atobe says, there's a lot of fluid in the torque converter. That fluid doesn't come out if you simply drain the fluid by pulling the drain bolt. The TC fluid will have to be forced out with a flush, which would then require extra fluid to refill the entire thing.
Note that, at least on the Gen 3 Camrys, the differential has a fluid reservoir of its own, apart from the transmission. It is drained and filled separately. Mind you, Toyota made the 'fill' process there WAY more painful than it should have been. For that one, get a gear oil/tranny fluid pump ($4.50 at the local O'Reilly store). Don't cheap out like I did, only to buy it later.
basil is offline   Reply With Quote
Old 10-10-2005, 09:39 AM   #4 (permalink)
View deekay140's Photo Gallery
What Kinda Car, Which Eng?
deekay140 is offline   Reply With Quote
