engine performance reduced when hot - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2005, 03:45 PM   #1 (permalink)
View camry300's Photo Gallery
My 93 v6 performance is very good when the engine is cold but the performance decreases a bit when it is fully warm up. Waht could be the causes????
would it be the O2 sensor ( no cel light ) because O2 sensor only comes into the picture when the engine is fuuly warmed up?????? or other causes?
Please help
camry300 is offline   Reply With Quote
Old 10-09-2005, 07:30 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
how much is "a bit"?
all engines loose some power as hotter air is less dense so less air = less fuel = less power.
terrastrife is offline   Reply With Quote
Old 10-09-2005, 07:50 PM   #3 (permalink)
well it is only by feel that the thottle response both partial or full thottle will be less pep when the engine is fully warmed up. ??????
Old 10-10-2005, 02:46 PM   #4 (permalink)
Gameroom cash: $304355
Check the ECT (engine coolant temp sensor). It may be a slight bit out of spec (not enough to throw a code) and causing an overly rich condition when warm. It may think the engine is still a bit cold. You can check it with a DVM. The specs should be in the skinny at the top of this forum.
Mike
Old 10-10-2005, 03:00 PM   #5 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
my car is the same way. The ECU tends to add more fuel to get the engine hotter for the Air/Fuel sensor to work properly. So you may get better performance when cold but it will suck on gas milige.
I have a problem where my ECU thinks my engine is alsways cold and so i waste alot of gas.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
