Start then.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2005, 08:50 PM   #1 (permalink)
View stir_fry_boy's Photo Gallery
4th Generation Start then....
A couple of times I have gone out to start my car, and it starts but takes 3 fires then it dies. Without turning the key to off, I make another attempt to start the car, it takes 3 fires then dies. I turn the key to off, then back to start, then it fires right up. I was wondering if the fuel filter could be clogged or something I hope it is not a fuel pump issue as those are much more expensive than a filter. What do you think?
stir_fry_boy is offline   Reply With Quote
Old 10-09-2005, 08:53 PM   #2 (permalink)
Mad Aussie Toy Owner
toyboyracer's Avatar
View toyboyracer's Photo Gallery
Australia
If it's NOT the fuel filter...
Fouled/faulty plugs is my guees
Some people are like slinkies,,,,Not really good for anything,,,,
But they still bring a smile to your face when you push them down a flight of stairs
Unfortunately evreyone has an opinion [q] ME [/q]
"The Thunder From Down Under"
http://www.camcrew.com.au
toyboyracer is offline   Reply With Quote
Old 10-09-2005, 09:15 PM   #3 (permalink)
They are dealer plugs and now have (according to the dealer records) 60k. I pulled one the other day to see what they looked like.....I couldn't tell that anything was wrong with them as they looked really good (in colour). I didn't know how to do the gap on a dual prong plug.
Old 10-09-2005, 09:25 PM   #4 (permalink)
B-Rad's Avatar
View B-Rad's Photo Gallery
If its not your fuel pump or plugs it might be your fuel lines. When your driving does it ever stall and feel like its going to die or is it just on startup? My girlfriends Accura 3.2 requires 91 octane and some dip before her used cheap 87 grade and plugged up the lines. If you get some residue in your lines it will plug them right up.
Friends Dont Let Friends Drive Stock.........
B-Rad is offline   Reply With Quote
Old 10-09-2005, 09:30 PM   #5 (permalink)
I have only had the car for 1.5k and about 1 month. It might be because it is getting colder. But it only happens when it is warmed up, shut off for 3 min, then try to start and only when I have driven it kinda hard (4k rpm shifts) this is why I think it is the fuel filter or pump. But after it warms up doesn't it get less fuel compared with when it is cold? It doesn't hesitate when I am driving at all....
Originally Posted by pgmomni
once warmed up, if you let it sit for a short while, will it start right up if its still warm?
i'm thinking its a prob with the idle enrichment under cold start conditions.
i think in the gen4 thats all part of the idle control valve isn't it?
or maybe its electrical!
Old 10-09-2005, 09:30 PM   #6 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
My freinds beretta had a fuel problem and it did that. Its probably your fuel delivery system.
Except my freinds beretta had Rotten Fuel lines and spilt gas everwhere
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 10-09-2005, 09:45 PM   #7 (permalink)
Australia
Search here & google for..... VAPOUR LOCK
Old 10-10-2005, 02:11 PM   #8 (permalink)
Wow! Thanks, and to answer your question, no it does not blow vapor pressure when I undo the cap after warming up and I gas the car up and it should (the cap came with the car, it passed inspection just 1 month ago) but it looks like an el-cheepo gas cap. I should go to the dealership and get a new one because I hate it when someone puts el-cheepo stuff on your car and it gives you problems. But first - I will try the gas cap. Second I will try the fuel filter, next, I will try spark plugs, then if worse comes to worse, then I will do the fuel pump. Thanks for your input and help.
Old 10-10-2005, 06:21 PM   #9 (permalink)
Got a gas cap, seems to do better, and the gas cap is soooo much better quality than the el-cheepo that was on the car. Anyone changed the spark plugs in a car like this? (V6 model)
