Random Parking Brake Light? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2005, 11:57 PM   #1 (permalink)
View FrankXT86's Photo Gallery
Alright...so recently my parking brake light has been randomly comming on. Like whenever I make a left turn or have the weight of the car shifted to the left side it come on. Now more and more it has been stuck on. Like the brake is all the way down and I've tried playing with it but nothing seems to work. I think it might be a messed up sensor.
I was wondering if you have ever heard of this before. I haven't gotten my brakes checked in the 40,000 miles that I've owned the car so I think I should bring it in soon and maybe have it checked out. Any ideas?
TIA
1999 Toyota Camry LE
2.2L I4 (5S-FE)
Mobil-1 5w-30 Synthetic
130K+ Miles
BF-Goodrich Revelation Tires
FrankXT86 is offline   Reply With Quote
Old 10-10-2005, 12:05 AM   #2 (permalink)
Watch for finger....
CamryRacer's Avatar
View CamryRacer's Photo Gallery
check your break fluid that was what mine was especially if it only comes on when you are going up or down hills
94 Camry LE V6----RIP
1987 Supra Turbo---Current Project
CamryRacer is offline   Reply With Quote
Old 10-10-2005, 12:48 AM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
^ what he said
and jut fill it up more even if it looks full- looks can be deceiving
HaHa
Old 10-11-2005, 11:49 AM   #4 (permalink)
View michellelee69's Photo Gallery
Brake Fluid
Check your brake fluid. I have an '01 Camry, did the same thing. Checked the fluid and it was low.
HTH
michellelee69 is offline   Reply With Quote
Old 10-11-2005, 12:38 PM   #5 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Well you can check the brake fluid since the sensor in teh master cylinder is probably the culprit for the light coming on. However Brake fluid doesnt jsut disappear. The most likely reason you are getting the light coming on is due to the fact the pads are worn and there is more fluid being used to fill the calipers sincethey have been lushed out farther. If you jsut want the light to go off top off your brake fluid. if you want to make sure you dont need brakes also have them checked or check them yourself.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 10-11-2005, 03:19 PM   #6 (permalink)
Brake Fluid
Cyorke,
You are ABSOLUTELY CORRECT. I found this out the hard way....
My brake light came on and I filled it with fluid. A short time later I replaced the pads....and guess what.....the extra fluid that I put it ended up being too much for the new pads and it some fluid came back out the top.
Definately a learning experience.
Old 10-11-2005, 04:42 PM   #7 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
PARKING break light is diff than a break light if its anything like my '93. Parking break, as always, is cable operated....not brake fluid dependent....i had a similar problem with my car, it wouldnt go off, then sumtimes it would...turns out i just had to slightly tighten the parking break cable via middle console
ag6286 is offline   Reply With Quote
Old 10-11-2005, 04:56 PM   #8 (permalink)
View infox's Photo Gallery
no, there are some camrys (mine included) where the parking brake light and the check brake light are the same thing (which I also just found out) because I'm also having the same issue as this guy.
infox is offline   Reply With Quote
Old 10-11-2005, 05:08 PM   #9 (permalink)
Moving Forward
Originally Posted by michellelee69
Cyorke,
Yes and brake fluid can be very corrosive to paint. SO if you have this happne you will want to try and clean as much of the spilled brake fluid off as possible.
Chris
Old 10-11-2005, 05:41 PM   #10 (permalink)
interesting....maybe an OBDII thing?
Old 11-24-2005, 12:24 PM   #11 (permalink)
View webwesen's Photo Gallery
definitely a stupid question, but still...
what reservoir to check for the brake fluid? is it the one in the right top corner of '01 Camry (when standing in front of the car)?
my 'Brake' light is going on and off for the last couple of weeks.
thanks in advance.
webwesen is offline   Reply With Quote
Old 11-24-2005, 01:58 PM   #12 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
The brake fluid reservoir is near the firewall on the driver side.
2007 Camry 2.4L 5M
Old 11-24-2005, 02:30 PM   #13 (permalink)
TN Pussy Man
open them all up and take a look if that helps..
it's the one that contains liquid that's almost like cooking oil, but more viscous
HaHa
Old 11-24-2005, 02:50 PM   #14 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
For the record, I've also had this problem.
BlueFusion6851 is offline   Reply With Quote
Old 11-24-2005, 05:23 PM   #15 (permalink)
Question
hm... checked - yellowish fluid - the reservoir is almost full.
some ppl here advised to look into 'master cylinder' - and apparently it should take no longer than 30 seconds - where is this one?
thx again
