Question on hp hook ups - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2005, 01:18 AM   #1 (permalink)
View javolin13's Photo Gallery
Is it possible to hook up a Turbo charger, and a supercharger together? Or will i need to choose one or the other?
javolin13 is offline   Reply With Quote
Old 10-10-2005, 01:19 AM   #2 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
Super Low end, Turbo High end revs. If you combine them on a stock engine the pressure will blow your engine apart
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 10-10-2005, 01:23 AM   #3 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397085
View RningOnFumes's Photo Gallery
well....couldn't you make one come on as the other goes off....big money investment.
...like twin turbo hoook ups.
supercharger first then turbo after it spins up
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 10-10-2005, 01:24 AM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
parallel or series. both will work, but getting them to work efficently is a different matter altogether.
superchargers providing oodles of low end is just a belleif ppl have. sc are better for top end as higher rpms preduce more boost, and in the low revs the sc drain on the engine is noticible.
a turbo can suit both. you can have a turbo providing fullboost as early as 1500rpm or earlier and good boost all teh way to the redline. or you can get some oversized bastard that begines to spool at a much greater engine load but then just break ya back at the redline
terrastrife is offline   Reply With Quote
Old 10-10-2005, 01:25 AM   #5 (permalink)
but is it possible to hook up on the same engine? For instince... have supercharger / inner cooler for one thing, then have the turbo charger w/ switch to turn off and on... is it possible to put both on the same engine?
Old 10-10-2005, 01:27 AM   #6 (permalink)
i jsut said yes... it will work in either parallel (both chargers into the intake seperately) or series (turbo into super into intake)
did you even read?
Old 10-10-2005, 01:29 AM   #7 (permalink)
sorry i was reading the second one then hit reply and replied before yours popped up.
Old 10-10-2005, 01:29 AM   #8 (permalink)
Midship Captain
ModifierMR's Avatar
hmmm i didnt not know that....someone told me it shouldnt be done!!! Yay at least someone can correct me cause i aint that automotive savvy.
すべての日本への私のお悔やみ。
Old 10-10-2005, 01:36 AM   #9 (permalink)
1993 Camry XLE
HoboJoe's Avatar
View HoboJoe's Photo Gallery
This would be awesome.
HoboJoe is offline   Reply With Quote
Old 10-10-2005, 01:40 AM   #10 (permalink)
it would also be a waste of engineering.
i say: turbo if you have a 3s, 5s, 2a
super if you have a 1m
work the shit outta it if you have a 3vz -remember that 3vz sw20 pushing 220whp (engine mangement, porting, cams, pistons) its getting MORE now
Old 10-10-2005, 01:45 AM   #11 (permalink)
1993 Camry XLE
HoboJoe's Avatar
So wait, what are you suggesting you do with the 3vz?
Old 10-10-2005, 01:48 AM   #12 (permalink)
try reading what i just typed...
Old 10-10-2005, 01:51 AM   #13 (permalink)
1993 Camry XLE
HoboJoe's Avatar
I did, and I have no clue what sw20 is. And what is it getting more of?
