Trunk Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2005, 10:27 PM   #1 (permalink)
View vasgs4's Photo Gallery
3rd Generation Trunk Question
My trunk does not open with the key, it opens perfectly fine from inside, but the key just does nothing. Is there a switch or something in the 3rd gen? My spec v had one, and I am just hoping this car has one too, cuz it would be nice to be able to use a key. thanks in advance for any info!!
vasgs4 is offline   Reply With Quote
Old 10-10-2005, 10:30 PM   #2 (permalink)
Gameroom cash: $926800
iTrader Score: 13 reviews
View ASG14's Photo Gallery
First off, which key are you using? There is 1 key that WILL not open the trunk, it's the Vale (sp?) key you use when you have someone park your car. The top of that key looks kinda like a triangle
5 Lug Corolla WHAT?
Old 10-10-2005, 10:58 PM   #3 (permalink)
View Grayguy's Photo Gallery
I'm pretty sure all gen3s have one key that does everything.
Does the key actually turn in the lock, or not. If the key turns, but nothing happens, I would sugest taking the trunk liner off and checking to make sure all the rods are connceted properly and not binding anywhere.
If the key doesn't turn at all, I suggest that you sparay some wd-40 or other spray lubricant into the lock and see if that frees it up at all.
Grayguy is offline   Reply With Quote
Old 10-10-2005, 11:01 PM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
you hav ea valet key that cant open the glovebox or trunk.
terrastrife is offline   Reply With Quote
