Car is Extremely Hard to Start in the Rain,Distributor Removal? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-11-2005, 02:22 PM   #1 (permalink)
5spd V6 ClrTail's Avatar
View 5spd V6 ClrTail's Photo Gallery
I know the Distributor is catching moisture. How do i remove it and dry it? Car doesn't wanna start after a long rain.
It's a : 92 V6 Camry 5sp.
5spd V6 ClrTail is offline   Reply With Quote
Old 10-11-2005, 03:47 PM   #2 (permalink)
Does any 1 know of this problem?
Old 10-11-2005, 04:52 PM   #3 (permalink)
I need help, car isn't starting.
Old 10-11-2005, 05:09 PM   #4 (permalink)
View Gary_602Z's Photo Gallery
Just replace it! Normally moisture will only effect a distributor if you have carbon tracks starting in it. Also check your spark plug wires.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 10-11-2005, 05:53 PM   #5 (permalink)
Does any one know why this happens when it rains and the car has been sitting over night? It just doesn't wanna turn over, and when it does, it idles rough until it warms up, i'm guessing until something dries.
Old 10-11-2005, 05:54 PM   #6 (permalink)
rusty9's Avatar
Gameroom cash: $441505
View rusty9's Photo Gallery
just change the cap, rotor and wires. you shouldnt need to replace the whole distributor. its happening becuase the cap or wires are cracked/broken and moisture is getting in there and the spark is either jumping to the wrong wire or grounding off a wire to the engine somewhere. try spritzing the wires with water when its running...if you see sparks or it starts acting rough again replace the wires.
rusty9 is offline   Reply With Quote
Old 10-12-2005, 06:12 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Also check the coil. IE: measure the primary and secondary resistance.
http://www.autozone.com/servlet/UiBr...3d8013e35c.jsp
Sometimes the coil will go bad or crack and cause problems.
"Skoolin' the unlearned!"
Old 09-10-2007, 10:56 AM   #8 (permalink)
The bucket owns you!
ChevelleSSLS6's Avatar
View ChevelleSSLS6's Photo Gallery
check the battery if it starts hard, check the wires if it runs rough (especially if it misses) and the coils tend to go bad on these things.
-matt
p.s. check my battery thread in the gen1/2 cammy section
ChevelleSSLS6 is offline   Reply With Quote
Old 09-10-2007, 02:46 PM   #9 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
This thread is 2 years old man...
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
