rear defroster - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-13-2005, 09:45 PM   #1 (permalink)
View smitdawg97030's Photo Gallery
3rd Generation rear defroster
93 rear defroster not working,is it a fuse or a relay ? Where is it located?
smitdawg97030 is offline   Reply With Quote
Old 10-13-2005, 10:01 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Check the fuse first. It could be on the driver side bottom dash. There should be a panel or coin drawer. Look in there for a burnt fuse.
If not there, look under the hood on the right side near the battery. There is a big plastic cover over all the fuses.
If you have a multimeter or test light, see if you get any power from the wire on the back that connects to the defroster lines. A cut line somewhere could cause it not to work also.
2007 Camry 2.4L 5M
