Originally Posted by jr_certs
I checked my Chilton's and I can't find any wiring diagrams. So could someone tell me where th wiring harness is on a Gen2 for the tail lights? Thanks.
What exactly do you mean? All the wires that go to the trunk pretty much go down the drivers side of the car. You will see them in the trunk coming in right above the driver's side rear strut tower... you can find the wire colors you are interested in at the sockets, and go from there. You will need a multimeter or test like to test everything. I believe the rear brake light failure sensor hides behind the plastic cover on the driver's side of the trunk if you can trace things that far... Good luck!
-Charlie
PS. I have a Hayne's manual, and I can probably find the wiring colors you are interested in if you can't figure it out... Email me if you need 'em.
