Flywheel is wrong!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2005, 11:22 AM   #1 (permalink)
View ImageMotorsport's Photo Gallery
vent on...
So i bring my Camry in to work to get the clucth and flywheel installed..
They pull the car in, pull it apart and find that the flywheel i bought has a different center bolt pattern than the crank...
DAMMIT!!! now I have to deside if I either
A make the shop at work wait till i can get the correct one, if it exist since this is supposed to be correct already
B Get the stock one lightened, and balanced
C just dont bother with a lighter flywheel
vent off
Can anyone tell me if I just have a car that there is no flywheel for? I bought from fidanza the correct part # for a 92 camry v6...I was getting told by the tech that some Jap produced camrys had a different crank and may not be as easy to find a flywheel for...Does this sound viable?
ImageMotorsport is offline   Reply With Quote
Old 10-15-2005, 11:29 AM   #2 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
they must have sent you the wrong flywheel. 92-00+ V6 cranks, both 3VZ and 1MZ, have the same 8-bolt pattern.
ratko.org
Ratko is offline   Reply With Quote
Old 10-15-2005, 12:03 PM   #3 (permalink)
yeah, its 8 bolt and pretty close to correct, mine is just spread out more than the flywheel every so slightly and the bolts on my car are tiny compared to the holes in the flywheel.
BTW: Ratko, did you get my pm from the other day?
Old 10-15-2005, 08:50 PM   #4 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
^ And so is the 88-91 2VZ...the same.
(Because i'm using a 93 3VZ flywheel on mine)
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 10-16-2005, 12:04 AM   #5 (permalink)
Art In Motion
Mayne Event's Avatar
View Mayne Event's Photo Gallery
if not just resurface your stock flywheel and call it a day.........
There are no stupid questions, Just stupid people.
http://www.cardomain.com/id/badblood
Mayne Event is offline   Reply With Quote
