Change timing belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2005, 05:58 PM   #1 (permalink)
View Reppinshadyvill's Photo Gallery
4th Generation Change timing belt?
Sup all, 2001 camry 63,000 miles. The dealer says that my car is due for the timing belt service. In my haynes it says that it can last up to 90,000 unless operated in sever conditions. I already know that I will NOT be letting the dealer perform this service but I am thinking about the timing of it. Winter is coming soon and I would hate for anything stupid to happed to my ride. So I need feedback can my belt make it through this winter season and be swapped this spring or should I just get it done now?
What intervals do you guys usually change your belts at?
Reppinshadyvill is offline   Reply With Quote
Old 10-15-2005, 06:25 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
It's supposed to be changed around 90 000 miles. You should be fine.
If the timing belt breaks, the engine just stops and you need to replace the belt.
2007 Camry 2.4L 5M
Old 10-15-2005, 06:30 PM   #3 (permalink)
Ok kool So then the 4 cyl camry is a non interference engine... meaning I will not mash up my valves if the belt breaks?
Old 10-15-2005, 06:50 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
no ya wont
Old 10-15-2005, 08:01 PM   #5 (permalink)
View steve97's Photo Gallery
My buddy had a Passat. TBelt broke. Interference engine. Mashed valves. $2500!
steve97 is offline   Reply With Quote
Old 10-15-2005, 08:41 PM   #6 (permalink)
Yup, the Gen 4, 4 cyl engine is non-interference.
Generally, Toyota engines with timing belts are non-interference, and those with timing chains are interference. There are a few exceptions though, but I don't know which ones they are.
2007 Camry 2.4L 5M
Old 10-15-2005, 10:42 PM   #7 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
it is 90,000 miles.
according to manual, gen 3 says 60k, gen 4 says 90k.
that is according to the car manual..
u should be OK for the next 20-30k.
skewe is offline   Reply With Quote
Old 10-16-2005, 08:39 PM   #8 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
I just changed mine on my 98 over the Canadian Thanksgiving weekend.
I was at 140,000 km (87,500 mi) so I was about 10 000 km early.
The reasoning was that the weather will get cold soon and I do not want to do it then.
If you go to the garage, or dealer it shouldn't matter to them when you coose to have it done.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 10-17-2005, 08:49 AM   #9 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
4th Generation
I'm getting my belt changed and just an over all tune up next week...my car will be at about 89K. So far so good, cept it has trouble starting up if i shut it off and turn it back on again....hopefully new plugs will do the trick.
nodrogkam is offline   Reply With Quote
Old 10-17-2005, 09:05 AM   #10 (permalink)
View TriumphGT6's Photo Gallery
Sunday, My dad and I finally got the engine pulled out of the $500 1998 Camry LE. The timing belt was changed 70,000 miles ago, according to the service records. The timing belt is $20.00 at Autozone. Now that the engine is out of the car, its really easy to change it. But with the engine in the car, it will take a good afternoon for you to do it.
The 4cyl Camry uses 14MM and 10MM bolts to hold on the cover. They were really easy to remove just using a strongarm. Then there is the timing belt tensioner, it is held on with a 14MM bolt, loosen, don't remove it, and the belt will loosen. Then remove the belt. Put on the new belt, and reassemble everything. There aren't really torque specs for this cover because all it does is keep dust off, no oil circulates near the belt.
It shouldn't be that hard if you remove the passengers side wheel.
TriumphGT6 is offline   Reply With Quote
Old 10-17-2005, 09:50 AM   #11 (permalink)
View tatvamasi's Photo Gallery
4th Generation
I changed it @95K. But when I took off old timing belt it was in very good condition and could have lasted another 30 to 40K but since i was in there i changed it anyways along with idler pullies. However I didn't changed the water pump and that sun of a gun is still working perfectly @170K. I am almost on my second timing belt due. Toyota water pump rocks!!!! may be?
tatvamasi is offline   Reply With Quote
Old 10-17-2005, 02:57 PM   #12 (permalink)
View Camry-rulez's Photo Gallery
and how about the 3VZ-FE engine?? If the timing belt brakes, will the engine stop and than just repalce the belt?? Help!! I've got on my timing belt now about 170000km (105000 miles)....
Euro CAMRY. 3.0 GX V6 (auto.) 1993'
Toyota Camry and Peugeot 205 Driver
Camry-rulez is offline   Reply With Quote
Old 10-17-2005, 04:20 PM   #13 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Yep same goes for the 3VZ. If it breakes jsut replace it and you should be good to go. ALong with any seals, water pump, tensioner and idler that may need to be replaced.
Another thing about t-belst. Just looking at them is not a very good way to tell if the beelt is good or not. They stretch over time and can be damaged by this. THey are not live serpetine or V-belts where they will crack and start showing signs of wear. I have seen them break at well under 60k miles and I have seen them go well over 120k miles(my Corolla and Pathfinder included). I did the t-belt on y pathfinder myself and when I took it off at 140k miles or so it looked jsut fine no signes of wear or anything but it may have broken the next day if I had not replaced it. You jsut never know.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 10-17-2005, 04:22 PM   #14 (permalink)
and how can I recognize that the timing belt must be replaced (waht is the diffrence by a new and an 90000miles timing belt?)
Old 10-17-2005, 04:26 PM   #15 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
if ya dont know how old it is, do it
