3S-GTE Specs ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2005, 08:48 AM   #1 (permalink)
Mad Aussie Toy Owner
toyboyracer's Avatar
View toyboyracer's Photo Gallery
Question 3S-GTE Specs ?
Ok, I know the GTE exhaust manifold will fit the 3S-FE (improved flow)
but is the inlet plenum better too and would swapping in the GTE cams
(ie the cam lift duration) be of use to a 3S-FE ?
Some people are like slinkies,,,,Not really good for anything,,,,
But they still bring a smile to your face when you push them down a flight of stairs
Unfortunately evreyone has an opinion [q] ME [/q]
"The Thunder From Down Under"
http://www.camcrew.com.au
toyboyracer is offline   Reply With Quote
Old 10-17-2005, 09:29 AM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Now Gordon....tell me how you propose to put G type cams in an F type head....??
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 10-17-2005, 09:54 AM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
the only thing that will fit both heads is the ex manifold, nothing else
Old 10-17-2005, 01:26 PM   #4 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $307675
And a gte exhaust manifold with NOT improve flow. It is only meant to be used with a turbo attached to it.
-Charlie
Old 10-17-2005, 04:57 PM   #5 (permalink)
The Other White Meat
terrastrife's Avatar
got lock?
terrastrife is offline   Reply With Quote
