Removing Fuel Neck/Inlet - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2005, 05:10 PM   #1 (permalink)
View PsychoPaul's Photo Gallery
3rd Generation Removing Fuel Neck/Inlet
I searched but didn't find anything on this topic.
i was wondering how do you remove the inlet/neck for the gas tank? basically where you fill it. I think mine has a small hole in it so i wan't to replace it.
Also is all the gen 3 and 3.5 compatible?
Thanks,
Paul
Paul
1993 Black Camry V6 LE
http://www.psychopaul.net
PsychoPaul is offline   Reply With Quote
Old 10-18-2005, 06:44 AM   #2 (permalink)
I'm guessing it's easier then i thought?
Paul
Old 10-18-2005, 08:18 AM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
download the repair manual that is linked inthe sticky at the top of the forum page and it will tell youfor sure. '
If i remmebr right you will need to open the gas door and there will be several small screws or bolts. Remove thoseand I think there may be a couple under the car. IT may also be easier to drop the entire tank to get to it. undo the screws at the filler neck then unplug the fuel pump under the back seat. Then there are two straps that hold the tank in place. Use a jack of some sort to support the tank then loosen the straps. THe entire assembly should drop down. Once you do this it is all right there in plain sight.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 10-18-2005, 04:52 PM   #4 (permalink)
i'll take a quick look and see in the manual. i'll aslo check my car quick quick.
Thanks for the info.
Paul
Old 10-18-2005, 05:07 PM   #5 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
haynes manual.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
