A/c Shuts Down When Put In Reverse?
When I Shift Into Reverse The Ac Shuts Down And The Temp Guage Drops To Cold,when I Take It Out Of Reverse Everthing Returns To Normal.really Confused What Is Happening.need Help.reverse Lights Dont Work Also.
1990 Camry 4 Cyl
FOUND THE PROBLEM THE WIRING HARNESS IN THE TRUNK ON LEFT SIDE,THE HINGE RUBS AGAINST THE WIRE AND BROKE IT.REPAIRED IT AND WIERD PROBLEM IS FIXED.HOWEVER BACK UP LIGHTS STILL OUT,ANY IDEA WHERE THE SWITCH IS?
