Water Injection system installed + more - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2005, 10:41 PM   #1 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
3rd Generation Water Injection system installed + more
My parts finally came in (from several places actually) for my water injection system. I must say living in Canada sucks when you order online in the USA at a place which only ships via USPS. My shit was shipped out almost a month and a half ago I finally received them two days ago
Anyway, hardware list is simple:
- CoolingMist (Shurflo) 60PSI Water Pump
- McMaster-Carr Water Solenoid
- McMaster-Carr Misting Nozzles
- McMaster-Carr 3/4" Pressure Gauge
- McMaster-Carr Needle Valve (Used as regulator)
- Electrical Parts such as Relays, Wiring, etc...
- 1/4" Tubing and Clamps
- Brass Fittings, etc...
- Solenoid and Pump Controlled by AEM EMS
The entire system was about $180. The system would cost a bit more if you rely on a boost pressure switch. I am just using my standalone to control the pump and solenoid.
Basic facts on Water Injection:
- Provides additional cooling during combustion
- Lowers EGT
- Allow a safer yet leaner air/fuel ratio
- Stretches the limit of pump gas
- Helps reduce carbon build-ups by steam cleaning
- Allows a larger margin of safety for tuning
I wouldn't bother with water injection unless you are reaching the limits of pump gas. With my turbo setup, I was pushing more than 160 HP/L and that's close to the limit of pump gas from what I've seen with over 10:1 CR. It was after my dyno session that I realized water injection would be a nice upgrade. I've also used water injection on my other car and it proved itself worthy.
Pic of the Water pump mounted:
Pics of pressure regulator, gauge, solenoid and water nozzle at charge pipe:
Dyno Session:
To add onto this thread, my recent trip to the dyno netted some okay results... This is what I have written on my homepage. I am posting the same info on here because Geoshitties have very limited bandwidth.
Link: http://www.geocities.com/leunghomepa...oOct13-05.html
Baseline Dyno Run:
The turbo Camry was once again strapped on the dyno. With a street tuned 14 PSI on the T66, it layed down an average of 320 WHP and 315 ft-lbs. Air/fuel ratio was in the high 10's which was leaned out later in the dyno session.
Final Dyno Numbers -- DYNORUN .013
After increasing the boost to 16 PSI and tuning with the AEM, the Camry puts down 391.7 WHP and 374.6 ft-lbs.
There were no ignition problems or timing problems, no heat or cooling problems. There was however, a little boost creep after 6500RPM and boost climbed up to 17 PSI. It was decided though that the car should rest after 13 dyno pulls and that was the day.
What's Next
With the automatic transmission and unlocked torque converter, there was a sigificant amount of driveline loss. Usually there is about 20-22% driveline loss, and this equates to roughly 480-490 flywheel HP. It is time to take caution when the engine is producing 160+ HP/L with 10.5:1 static compression ratio and running on pump gas. A water injection system will be installed shortly.
Here's the dyno printout:
Tuning Notes:
- Timing at torque peak @ 18 deg BTDC
- Timing at 6500RPM @ 24 deg BTDC
- Maximum Injector Duty @ 57%
- Air/Fuel Ratio @ 11.8:1 at peak boost
- 7 Heat Range NGK IX Iridium Plugs
Additional Notes:
With the high stall torque converter, the engine does not create actual power unless the RPM is at or above stall. The power curve on the dyno sheet does not reflect actual turbo spool time and powerband. In order to find the turbo spool RPM and powerband, the torque converter has to be fully locked.
I am assembling a video right now... It should be ready for download later this week And of course, I won't be happy until I touch 500WHP... The water injection will give me some confidence to further up the boost to 20+ PSI. I might try to put some race gas in the mix if I reach the limits of pump gas + water injection.
Comments are welcomed
* Goal for 2012 -- 200+ MPH in the Camry
Tony the Tiger is offline   Reply With Quote
Old 10-18-2005, 11:12 PM   #2 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
congrats on the numbers tony! i know what it is like to go into the dyno - and come out with a sheet a bit lower than you desired- but you know that is always better than coming out with a new engine to rebuild
the water injection is a very cool add on - my buddies roomate has his integra going on a built head + wi + stock bottom end, and he is boosting around 25 psi on a t3/t4 and no major issues yet - except he is a honda guy that has monkeyed the system around such that wires and crap is floating everywhere , but before the water injection he had been going on 20 psi - and now he said he was pulling a bit away from a friend that ran i believe consistent low 12's @ a recent drag day
do you have a website you would suggest to read up on high stall torque converters? I would like to understand that mechanism a little bit better - as i do not know much on them - and i am not sure how that is affecting the powerband...
really thought X100 great stuff man, i know there are only more updates to come - just know that you are the highest WHP camry in the world atm (excluding those camry-solara drag guys, running 2JZs)
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
Old 10-18-2005, 11:34 PM   #3 (permalink)
Local Rape Machine
View ekim55121's Photo Gallery
500 whp camry is awesome but with any thing over 350 my pants are now wet. good job man keep up the good work, awesome car
ekim55121 is offline   Reply With Quote
Old 10-18-2005, 11:36 PM   #4 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Damn can I send you my Camry and jsut do wahtever it is you did to your to mine. Do you think you ahve time for that. Hell I would be happy with half of what you got right now. I am not sure how my wife would feel about it afterwards. I probably wouldnt even have a wife afer something like that. Of course then I have to get another car to drive and on and on nad on. Well on second though maybe I will jsut ahve to live vicariously for a while.
Very sweet car Tony. Cant wait to see the next numbers you put up.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 10-18-2005, 11:46 PM   #5 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
Envious!!!
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 10-19-2005, 12:15 AM   #6 (permalink)
slowamatic noob
a94autoCamry's Avatar
Gameroom cash: $149910
View a94autoCamry's Photo Gallery
awesome tony, but your not happy until you get 500whp =
cant wait to see the video..
GL with your tuning
slow white - "no show and no go"
a94autoCamry is offline   Reply With Quote
Old 10-19-2005, 12:52 AM   #7 (permalink)
View 94CoupeV6's Photo Gallery
Please post any videos you have! Fucking marvelous job, it's a one of a kind car. Keep up the good work.
94CoupeV6 is offline   Reply With Quote
Old 10-19-2005, 01:10 AM   #8 (permalink)
View yosh's Photo Gallery
Simply amazing! Awesome numbers and good luck with the WI.
2000 Camry LE V6
TRD Supercharged
yosh is offline   Reply With Quote
Old 10-19-2005, 01:24 AM   #9 (permalink)
TN's Nikon Expert?
prnc_chrmng's Avatar
Gameroom cash: $491868
View prnc_chrmng's Photo Gallery
thats just orgyastic tony...
so when you gunna be on the cover of all the import mags??
Originally Posted by 98tercel_girlie
This thread needs more porn, less blah blah
prnc_chrmng is offline   Reply With Quote
Old 10-19-2005, 09:00 AM   #10 (permalink)
Mr. DSM
Keep's Avatar
View Keep's Photo Gallery
at 11.8:1...haha ...you've got so much room to play with Tony. What do your egt's look like?
Keep is offline   Reply With Quote
Old 10-19-2005, 03:31 PM   #11 (permalink)
toyota tuner
vsixcamry's Avatar
View vsixcamry's Photo Gallery
^ word, much room to work with. Good numbers though, very good infact. WATER INJECTION IS THE SHIT.. good stuff tony, keep up the good work
vsixcamry is offline   Reply With Quote
Old 10-19-2005, 03:55 PM   #12 (permalink)
SUPERCHARGED!
astro73's Avatar
View astro73's Photo Gallery
Simply amazing numbers!!!!!
Larry
'00 S/C Black Sand Pearl Solara SE V6 5spd
astro73 is offline   Reply With Quote
Old 10-19-2005, 04:28 PM   #13 (permalink)
Torqued Solara
Paladin06's Avatar
View Paladin06's Photo Gallery
Thumbs up
No doubt you are the man!!!
Visit my site and rate my ride.
http://www.cardomain.com/id/paladin06
Paladin06 is offline   Reply With Quote
Old 10-19-2005, 05:24 PM   #14 (permalink)
my name isn't really Bob
View Fresco Bob's Photo Gallery
that is just nuts! I dont know what else to say
Fresco Bob is offline   Reply With Quote
Old 10-19-2005, 06:13 PM   #15 (permalink)
-=the wheel man=-
Killa_Kojak's Avatar
View Killa_Kojak's Photo Gallery
for making a 400hp Camry .....i hope you bring it out for the East End meet so i can see the beast in person....ill have to park my camry in another lot so it doesnt see me to your car and gets jealous then throws CELs at me
1993 Toyota Camry LE Sport-Unnaturally Aspirated then killed
1997 Toyota Camry LE- aKa Purgatory Gray
Killa_Kojak is offline   Reply With Quote
