After reading Tony the Tigers report on Water Injection, it prompted me to write this thread.
Water Injection :
Helps reduce carbon buildups by steam cleaning
Here in Oz for a number of years we've had various de-carbon business's and it
"may" be something to look into if you have a
tired old engine.
As far as I can guess the "cleaning" would
remove carbon buildup from around valves which increases flow and would help with a whole range of associated problems.
Downside could be with carbon cleaned off
the top of the pistons a few lbs of compression may be lost...
Anyways I thought I'd mention it as an idea for people to look in to
As an after thought, if this is done and you suddenly have a fair bit more POWER,
DON'T go and start
flogging the motor as the
top ring will have left a
LIP in the
bore and by
"over reving'' the piston will
STRETCH thus
catching the ring on the
LIP
and
breaking it.
ALSO applies to
any car driven
SEDATELY then SUDDENLY given a bootfull !
Allways
"gently" increase the RPMS with any motor that's been driven NORMALLY or it's gunna go splat real quick...
